![]() | Home > Wheels & Tyres (L663) > TPMS - again |
Hairy Dan Member Since: 25 Apr 2013 Location: NW Durham Posts: 1445 ![]() ![]() ![]() |
Mine has a sensor in the spare but as far as I know it doesn't display the pressure anywhere. Cheers Ian
-------------------- 22MY Defender 110 D200 SE, Fuji White. Kielder 4x4 Safari Instagram @defender_v8 |
Lockley Member Since: 15 Feb 2023 Location: Herefordshire Posts: 16 ![]() ![]() |
If you rotate the tyres, the spare with the TPMS will then register in its new location and appear in the IDD. I've rotated my tyres myself every 5000 miles and this has worked every time.
abyss Member Since: 30 Sep 2017 Location: Melbourne Posts: 33 ![]() ![]() |
I bought a set of genuine 5 spokes 22” rims and fitted new genuine LR TPMS along with new tyres. After swapping it to my car (came with 19”). The car doesn’t recognise any reading now with 4 “X” in the reading. I drove the car for 2 days in various still nothing.
Does the genuine TMPS has be programmed? |
steam_simon Member Since: 24 Sep 2022 Location: London Posts: 95 ![]() ![]() |
As far as I know you do not need to reset them. I did replace my factory fitted wheels with a set of non-TPMS off-road wheels and the TPMS did not work (as expected).
When I subsequently replaced the off-roads with the original factory fitted wheels the TPMS worked almost instantly. The next step is to get the off-road tyres fitted with TPMS sensors and see what happens. I am assured by the vendor that they should work without any "re-setting", but others on this forum do seem to have had problems so I have my fingers crossed. |
Garthlands Member Since: 01 Dec 2021 Location: Glasgow Posts: 27 ![]() ![]() |
I bought a set of five "take offs" from my local dealer, for use as a second set of wheels and fitted them with off road tyres. First time on the car, new wheels worked with the TPMS system right away and when I swap wheels back to the road tyres, it picks them up right away too, no issues and no laptop involved at any point!
Tim in Scotland Member Since: 23 May 2007 Location: The Land that time forgot Posts: 3753 ![]() ![]() |
My now departed D240 110 had a receiver for the spare as well as the tyre TPMS sensor and the pressure showed up on the IDD TPMS page. My new 90 doesn’t display the spare’s pressure on the screen and I suspect as part of the penny pinching at JLR it’s because they didn’t fit a pick up head for it like my 110 had. One query I put to both the dealer and LRCS with my 110 was why the spare’s recommended pressure was so high at 50 psi and it set off the low pressure alarm at 47psi which was a pain.
When I took delivery of my 90 one of the things I did after leaving the showroom was to check what the tyre pressures were set at…….. 3 out of 4 were at near enough the correct light running pressure but the rear off side was set at 50psi! So much for the dealership doing a proper PDI - or maybe the work experience child was trusted to do that bit if it……. Pangea Green D250 90 HSE with Air Suspension, Off-road Pack, Towing Pack, Black Contrast roof , rear recovery eyes, Front bash plate, Classic flaps all round, extended wheel arch kit and a few bits from PowerfulUK Expel Clear Gloss PPF to come 2020 D240 1st Edition in Pangea Green with Acorn interior. Now gone - old faithful, no mechanical issues whatsoever ever but the leaks and rattles all over the place won’t be missed! |
