![]() | Home > Puma (Tdci) > How to fold rear seats - pull handle doesn’t seem to work? |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17918 ![]() ![]() ![]() |
Once you've freed the backs, the bases should tip normally, there are no additional fasteners.
edward Member Since: 08 Jan 2023 Location: Lincs Posts: 151 ![]() ![]() |
Thanks. Maybe they are just really stiff but they aren’t moving. I’ll just have to use more strength.
So yea it was simple in the end - although I could only get the double seat to tip once the single was tipped …
Also btw - my double cab doesn’t have strikers that can be flattened as in the manual? is that normal? (2013 puma) |
The DC strikers are fixed and can't be folded. I suppose that it might be possible to fit SW ones.
Thanks. I don’t think I’ll replace them - it’s just curious LR felt the need to change a part that doesn’t need changing!
