Home > General & Technical (L663) > How do I turn OFF the door mirror anti-glare
LR Nuts
Both door mirror, and rear view mirror, start off 'clear glass'
When starting all three mirrors turn on the (LCD?) anti-glare, in day or night mode.
How can I turn them OFF, is it selectable ?
Post #981077 3rd Feb 2023 10:50am
J77
No way to turn it off 24MY 90 D250 HSE, Tasman Blue
Post #981079 3rd Feb 2023 11:06am
lightning
Why would you want to turn it off?
Mine only does it if if it's very bright such as reversing into the sunlight
Post #981106 3rd Feb 2023 2:23pm
LR Nuts
Travelling at mid-winter Dawn and Dusk. I believe my vision is obscured, when dark coloured cars are around me.
I don't want to turn them off permanently, just during certain hours.
Post #981123 3rd Feb 2023 3:29pm
Moo
Ukraine
What is this? How do I know if I have it?
Post #981124 3rd Feb 2023 3:30pm
LR Nuts
I'll get some photos
Post #981126 3rd Feb 2023 3:32pm
XplusYplusZ
I think most defenders have it - you can see it best on the driver's wingmirror, it automatically darkens most of the mirror to reduce glare from headlights behind. You can still see a small outer layer of non-dimmed glass which helps you know it's switched on.
I think you can choose auto dim on/off in the menus, but i could be wrong.
Post #981466 6th Feb 2023 11:25am
LR Nuts
well after a lot of faff, I have finally got the 3 mirror set to turn off the 'LCD look'. as shown in right hand photo above.
Post #981678 7th Feb 2023 5:02pm
Retroanaconda
Care to share how you did it?
Post #981683 7th Feb 2023 5:23pm
LR Nuts
I must admit .......... I don't really know.
1. I turned ignition on WITHOUT starting engine. Selected headlamps to 'AUTO'
2. I moved centre sun visor to up position.
3. I prayed.
Now which one of above worked, or any permutation ?????
Post #981685 7th Feb 2023 5:44pm
LR Nuts
found this in the eManual.
Post #981702 7th Feb 2023 8:24pm
Buz1500
If you lower the centre sun visor this usually activates the dimming procedure. It always does in my car.
I rarely use the centre visor so I never found it an issue to be honest. You could say it was a benefit, allowing you to activate the function when desired when the automated process isn’t kicking in.
Post #981730 8th Feb 2023 9:51am
LR Nuts
I did a RTN journey to London today.
And YES the centre sun visor does turn on and off the 'LCD' in all three mirrors. If only people knew that !!
as for auto turn on-off still haven't worked that out ?? bearing in mind it takes around 8-10 secs to activate.
Post #981798 8th Feb 2023 6:35pm
LR Nuts
wrong thread
Post #1014125 6th Nov 2023 7:09pm
