Home > Td5 > Engine removal
Jim88er
England 1999 Defender 110 Td5 CSW Alpine White
Engine removal
I’ve got to remove my 10p engine from my 110sw. I’ve never removed a Td5 before so has anyone got any advice? I just want to do it as methodically as possible. Thanks.
Post #980632 31st Jan 2023 12:16pm
TexasRover
Remove radiator and intercooler first ( assuming no AC ) this will make access much easier. Otherwise pretty straight forward job
Post #980666 31st Jan 2023 2:42pm
Jim88er
It has got air conditioning. Would you remove the front grill too?
Post #980672 31st Jan 2023 3:25pm
Dinnu
Not removed a Td5, but removed an early engine without removing the radiator... but my engine hoist could not clear the radiator so removed the front wheels and dropped the front end as far it could go. In hindsight, I should have removed the radiator as the coolant was already drained, but since you have AC you might try to move the compressor out of the way and save you re gassing if you keep the rad in place.
The LT77 and transfer case combo balanced quite well on their mountings, So I trust that the R380 will balance just as fine. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #980703 31st Jan 2023 6:29pm
TexasRover
Sorry yes including front grille. But with AC you obviously want to try and preserve the gas and as said remove the compressor from the bracket and leave it in place.
Although it is not cramped by modern standards, after removing the radiator it took me maybe an hour to have the engine out with a standard engine hoist. The bell house bolts are very accessible with the engine sitting up front so removed the engine seperately. Even thinking changing a clutch could simpler this way, if like me you getting a little too old to wrestle a gearbox on a jack in the drive.
Post #980731 31st Jan 2023 9:26pm
