Home > Technical > How NOT to terminate a steel cable
leeds
Here are some examples of how NOT to terminate a steel cable. The most frightening thing about these photos are that they are of OFFICIAL rescue trucks. IF you see winch cables like these being deployed get out of the way, preferably a long way and be ready to call the ambulances if not hearse!
Whats wrong with this? No thimble and a home made thimble with no guarantee that the loop is strong enough. Also wire is twisted in the loop!
Whats wrong with this? No thimble, only two dog grips and wrongly spaced
A good ferrule but whats wrong? No thimble
Now have criticised all three of these terminations but the common one was no thimble. Why is that bad? You put a large load on a wide loop going around a bar say 1-2 diameters of the wire then it is bent so that the steel wire will be deformed forming a 'birds nest' This will result in things like galvanisation cracking, crushing and over stressing of the wire.
Now if your winch cable does not have a thimble in. (YES I know some winch manufacturers supply cables like this) take the cable off and get it terminated correctly. Your local chain/lifting specialist and they will do it for the cost of a few beers.
HTH
Brendan
Post #94305 14th Oct 2011 10:59pm
noworries4x4
The last one is how GENUINE warn cables are dispatched from the factory i have had mine remade, all bulldog grip terminations are illegal for lifting under loler but for recovery and towing another legislation grey area If everything is under control you are not going fast enough.
Every Day MY 20 Discovery 5 Commercial Workshop and Escort Vehicle
Weekends MY 12 L322 4.4 TDV8 Vogue
No Worries 4X4
Post #94422 15th Oct 2011 9:17pm
First thing I did with the steel cable that came with the ti was skip it
Post #94424 15th Oct 2011 9:23pm
leeds
Noworries SOME Warn winches come like that, others are CORRECTLY terminated with a thimble and mechanical splice.
I once asked a Warn rep why some were correctly terminated and some not, he did not know! The only reason I can think of is the bean counters have been trying to save a few cents.
Many years ago I worked as a test engineer for CCL. CCL made ferrules, dyes, hydraulic crimping presses, rebar connectors, suspension bridge mounting plates for main cables.
It was a big NO NO to make an eye in a wire cable WITHOUT supporting the eye with a thimble. Why is it such a big NO NO?
On loading an unsupported eye then the wire cable will open up/birds nest. This causes the stress in the wire cables not to be evenly taken by ALL the individual strands. This means that some of the strands will fail early resulting in the cable failing BELOW its design strength. You can see the cable beginning open up on the photos I posted.
The worrying thing is that I took those photos on official fire and rescue trucks.
I believe that if you identify a possible problem you solve that problem before it actually bites you in the bum so to speak.
If your winch rope is terminated like those in my photos my recommendation would be to get it terminated correctly ASAP
Brendan
Post #94435 15th Oct 2011 10:08pm
bm52
United Kingdom 2014 Defender 110 Puma 2.2 XS CSW Havana
can you educate me with a pic of a correctly finished steel cable for a winch.
thanks BM52
Post #94438 15th Oct 2011 10:17pm
leeds
Hi bm52, sorry but I have not taken one of a correctly terminated winch cable.
However a quick google and I found this one. OK not of a winch but shows what a proper hard eye looks like. Am sure you can use your imagination now! Razz
In my opinion the correct way of terminating a winch cable is with a thimble in the eye.
Brendan
Post #94441 15th Oct 2011 10:45pm
bm52
now it becomes clear and makes sense. i see what you mean if the cable does'nt have an eye it will probably loosen the 'twist' and then start failing.
cheers for the lesson Thumbs Up BM52
Post #94448 15th Oct 2011 11:21pm
leeds
Back in the olden days we used to make our own caving ladders and belays.
Yes it was quickly found out that 6/19 FC (fibre core) wire rope was not a brilliant idea as they could rust from the inside.
Not really a good idea so 7/19 3mm (steel core) wire rope was used instead. C links for joining ladders and belays were made by hacksawing a cross through the weld in 5/16 welded chain.
If it had been safe not to use a thimble to form a fixed loop we would have saved ourselves a few pennies. However our lives were worth more then a couple of pennies.
Now can you imagine what H & S would make of it these days? Home made load bearing, life dependent equipment being made by uncertified (well be might have been certifiable!) personnel on uncertified equipment, without a SWL etc etc. luckily we had access to tensile test machines!
Once tested some ankle harnesses for bungee jumping. The wooden 'ankles' we used failed at 1.8 tonnes with no sign of damage to the harness. I decided they were strong enough as 1.8 tonnes applied to your ankles would probably rip your hips apart. No H & S! Those were the days Razz
Ooops sorry gone off on a tangent.
Brendan
Post #94450 15th Oct 2011 11:41pm
willy eckerslike
United Kingdom 2007 Defender 110 Puma 2.4 HCPU Keswick Green
We use hundreds of wire ropes daily that are not terminated with a thimble and are perfectly safe. the difference lies in the winch line on your winch if used in lifting would be rated at 1 ton safe working load, yet we regularly winch about 2 1/2 ton vehicles and generally abuse the wire in doing so, that is why as Brendan says we should take every effort to look after our wires / ropes and use hard eyes in terminations. A good thing to learn is how to yankee splice and use bulldogs, this is a safe and strong way to re-terminate a snapped wqire out in the field. The flat ferrule in the photos is typically American and can still be bought, though they aren't very reliable.
Todays job is to un-reeve our 10 line system from the Drilling block and re-reeve back to 12 lines, 1 3/4" rope 160' between blocks. We are shortly going to run a string of casing that weighs 1,000,000 lb hence the need for extra lines. Original Member Pie n Pea Club.
110 HCPU Tipper
Post #94467 16th Oct 2011 8:16am
Paul_1978
England 2004 Defender 90 Td5 CSW Zermatt Silver
We also have hundreds of wire ropes or strops with no thimble fitted.
These strops come in swl from 1T to 100T, if the strop is pulled like in a winch situation, the thimble would crush flat anyway.
Only strops with thimbles are used on dogging hoists to detech lifting tongues from steel slab or blooms, and these use D links as attachments to the lifting equipment.
I can appriciate the other examples you have shown being unsafe, but not the latter photo.
Post #94470 16th Oct 2011 9:02am
Paul_1978
Brendan
In life line of fall arreset stiuations the structure you are being attached to must be rated to take a 1T shock load, thats the force which is applied to the system when an average human falls and is held via a harness. So 1.8T with no shock asorbance would probabally kill you, pleanty of shock asorbance in a bungee rope tho.
Post #94471 16th Oct 2011 9:05am
party monkey
England 2005 Defender 110 Td5 XS CSW Cairns Blue
Slightly off the topic of winch lines but same question really with regard to tow ropes ....
Among the small collection of recovery ropes/straps that I have. I've got a tow rope which, from memory, is rated to about 8mt that was supplied with metal thimbles in the loops.
I took them out as felt that in the event of a failure on the rope or some other element in the recovery , there was one less bit of metal potentially flying around....
Are they really necessary on a synthetic recovery rope ?...... Jon - 110 td5 [sold]. Currently Defenderless.
Post #94472 16th Oct 2011 9:08am
leeds
PM, answer is a sort of yes and a no.
The larger the diameter of a test bollard when testing a strap or rope the larger the apparent strength is! Obviously the physical properties have not changed it is just an artefact of test methods. Other things alter the apparent strength of materials, things like temperature, speed of testing, test 'vibration frequency' etc.
In a 'leisure' recovery situation people often do not understand possible forces involved, a read of Billyvista recovery bible is worthwhile reading. Forces involved could well be twice weight of vehicle!
The basic rule I work to is that any lump of metal involved should be firmly attached to a vehicle or fixed anchor. Reduce the potential of number of bits of metal flying when things go tits up!
When joining straps or ropes together do NOT use shackles.
Brendan
Post #94475 16th Oct 2011 9:31am
willy eckerslike
You can also use a light piece of wood Original Member Pie n Pea Club.
110 HCPU Tipper
Post #94477 16th Oct 2011 9:56am
leeds
Called in at local winch shop yesterday. About 15-20 winches on display with steel wire ropes. All had thimbles in including Warn winches. Sales manager could not remember any steel wire without thimble/fixed loop in.
Our cheap electric hoist/winch (used for lifting roof tents up) also has a thimble/fixed eye in.
Brendan
Post #95535 21st Oct 2011 11:26pm
