Home > Technical > Parasitic load central locking
bear100
I’ve noticed I have a parasitic load, tbh it’s been there’s while and just have had the time or the weather to look into it Shocked
At rest I have 65-72mA
It was spiking from in the hundreds to 56mA disconnecting the UltraGauge from the OBD has fixed it.
After removing all the usual culprits eg relays with no luck, I then started on the fuses and found that the central locking is pulling at rest 40mA removing this fuse drops to 23 and as low as 7mA
I’ve disconnected all the actuators one by one but no difference. I think this fuse is also linked to the immobiliser because when removed the red led stops flashing.
So where would you suggest I look next? I’m a bit stumped Big Cry 2023 Defender L663 V8
2010 110 XS Utility 2.4TDCI
1993 110 csw 200 tdi (gone)
1994 90 HT 300 tdi (gone)
1994 discovery 300tdi (gone)
90 hybrid 3.5 v8 (gone)
Post #980324 29th Jan 2023 3:30pm
landy andy
Have you tried disconnecting the internal volumetric sensor?
Post #980354 29th Jan 2023 5:45pm
bear100
I didn’t think of that, I will give it try
Thanks Thumbs Up 2023 Defender L663 V8
Post #980359 29th Jan 2023 6:00pm
