Home > Puma (Tdci) > Gear oil - Snake oil?
ZeDefender
Well... the Motul Gear 300 oil did improve the gearbox... whilst the weather was warmer Rolling Eyes
Now we're at zero this morning and second gear was almost impossible Sad
I know, I know - everyone has this problem but has anyone found a way to improve it?
As the box is constant mesh, I suppose leaving the engine running (neutral with clutch engaged) might help by churning things up a bit (there goes another iceberg) - or am I barking?
The other idea is an additive, such as Liqui Moly Getriebeoil-Additiv. Anyone got first-hand experience of additives in cold weather?
It won't be long until we're at -10, -15 etc. so I'm trying to get prepared Shocked
Cheers,
Matt Tell someone you love them today because life is short.
Post #94166 14th Oct 2011 9:08am
MK
Been below 0º, with and without LM additive. Use your warranty Puma 110" SW
Post #94183 14th Oct 2011 9:47am
MartinK
DGARDEL had good results with additives:
http://www.defender2.net/forum/topic2139.html?highlight=ceramic Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
Post #94189 14th Oct 2011 10:07am
ZeDefender
Yep - I also had CPL in the box until recently but have now re-filled with the Motul when I thought I might need to use the warranty (CPL is really obvious in the oil!). Now decided to live with the box until later date when I can prove to LR that it's crap but wondering what to do about cold-starting in the meantime... Tell someone you love them today because life is short.
Post #94191 14th Oct 2011 10:28am
