Home > Td5 > Rivet Plastic Snap in Fuel Tank Heat Shield - replacement
doruk1981
Switzerland 2002 Defender 110 Td5 SW Coniston Green
Hi,
I need to pull my fuel tank for replacing the rear crossmember and therefore I wanted to order a new set of rivets for the heat shield (rivet part number: WYQ100040)
it seems that this piece is sold out quite everywhere. Is there an alternative part that can do the trick? I checked out lrworkshop.com but am not certain. I managed to get one from LRparts.net but would still need to find 2 additional units according to the LRworkshop.com diagrams
thanks for the hint Td5 110 Station
Post #978961 20th Jan 2023 12:57pm
Ianh
As you now have one at hand you can measure the key elements of it then do a internet search on trim clips, trim fastener, plastic rivet clips etc. There is bound to be a generic one that is more or less the same.
Ps. Can you post a couple of pics and dimensions of the item, that would help.
Post #978964 20th Jan 2023 1:33pm
Martin
Site Admin
Take some measurements from the one you have and you will likely find something similar here:
https://www.vehicleclips.co.uk/collections...=grid-view  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #978966 20th Jan 2023 1:45pm
doruk1981
generic ones would go? thats great news. thanks for the hint. I was thinking of them but then again, its a fuel cell related thing so a little confusion remained. Td5 110 Station
Post #978972 20th Jan 2023 2:39pm
