![]() | Home > In Car Electronics > Reverse signal feed |
| roel Member Since: 08 Aug 2009 Location: Lelystad Posts: 2039
I think the closed is at the top off the gearbox. Roel
| Penfold_6290 Member Since: 22 Sep 2021 Location: Dorset Posts: 396
I’ve just replied to your other post, this is the connector for the reverse switch, left hand side of gearbox.
Click image to enlarge |
| Poulstonb Member Since: 30 Jun 2022 Location: Styal Posts: 88
So do I tap into the green or grey wire ?
The wires are GN (green with brown trace) and GY (green with yellow trace). You want the green and brown wire as that will become live when the vehicle is in reverse and the reverse switch is closed.
Perfect thanks
| GM_FFX Member Since: 15 Sep 2021 Location: Washington DC Posts: 31
did you end up tapping into those wires? How did you get to them?
No the camera had an additional wire that was spare and ran with the jack lead, I connected the reverse signs feed to it on the head unit , then at camera end cut it and spliced into the reverse light live .
That's what I was thinking too, quick question, does the camera have a delay function or the screen constantly turns off while parking and shifting from reverse to first gear?
Just switches on/off when reverse is selected
