2.2 Brown 110 Utility
Here is my 2013 Puma, I only purchased it a couple of months ago and its had a pretty hard working life and had 120,000 on the clock when I bought it and came with a list of age related problems that need fixing.
So far the list of work done is…
Replaced rear half shafts with LOF Solid HD Rear drive half shafts to fix the clunk
Replaced the rear prop shaft with a Terrafirma one
BAS 170 tune with BAS Intercooler and silicone hoses
Added a Terrafirma rear wheel carrier
Rewired the lights behind the heater controls (a really strange 5.8v problem that still needs proper investigation)
RedBooster clutch servo assist (still needs to be fitted)
The list of things still to do includes
Fix the strange 5.8v problem on the centre console lighting circuit
Fit a LOF Road Clutch kit with solid output shaft
Replace all fluids
Clean injectors
Find and fix the leak that causes a puddle to appear in both footwells after heavy rain
Fit sound deadening and Exmoor carpet set, its a utility so has nothing at the moment
Improve the ride and handling, I believe it has the HD springs, and the dampers have done 120k so a new set of springs and shocks would not go amiss
Fix or replace the heated rear window elements
Choose a roof rack
Air filter box fan removal
Centre exhaust silencer delete
Bowler 18” wheels
Masai front bumper
Etc….
I’ll keep a record here of everything that gets done from now on
8th Jan 2023 7:41pm
JOW240725
Looks a great 110, good luck with your journey, sounds like its going to be well looked after
