Home > Maintenance & Modifications > Swivel hub pre load
Sith
Australia
Swivel hub pre load
Hey all ,
This weekend I am playing the shims game with my swivel hubs . Can anyone pass on any tips or vital advice ?
thanks so much in advance Knickers , not the best thing in the world ... but right next to the best thing in the world
Post #93865 12th Oct 2011 2:56pm
ickle
Sorry, its a fiddle, wear gloves as the grease stains!
Keith
Post #93945 12th Oct 2011 10:18pm
bm52
United Kingdom 2014 Defender 110 Puma 2.2 XS CSW Havana
does this help - see number 34
Install upper and lower bearing tracks into swivel bearing
housing.
22. With seal lips trailing, install swivel housing inner oil seal
into rear of housing. Grease seal lips.
23. Coat swivel bearing housing to axle casing bolts with
sealant, Part No. STC 50552.
24. Coat both sides of joint washer with a sealing compound.
Position swivel bearing housing to axle mating face.
25. Place retaining plate, joint washer and oil seal over axle
flange ready for assembly.
26. Install swivel bearing housing to axle flange with 7 bolts.
Tighten to 73 Nm (54 lbf.ft).
27. Grease and install upper and lower swivel pin taper roller
bearings.
28. Position swivel pin housing over swivel bearing housing.
29. Coat joint washer both sides with sealing compound and
position on lower swivel pin.
30. Loosely install brake shield bracket plus lower swivel pin
with lug outboard to swivel pin housing.
31. Loosely install top swivel pin plus existing shims and brake
hose bracket to swivel pin housing.
32. Apply sealant, Part No. STC 50552 to threads of lower
swivel pin bolts; tighten bolts to 25 Nm (18 lbf.ft), bend over
lock tabs.
33. Apply sealant Part No. STC 50552 to threads of top swivel
pin bolts, install bolts and tighten to 65 Nm (48 lbf.ft).
34. NOTE: Swivel housing oil seal and axle should not be
148 of 1212
fitted.
Attach a spring balance to track rod ball joint bore and pull
balance to determine effort required to turn swivel pin
housing. Resistance, once initial inertia has been overcome,
should be 1.16 to 1.46 kg. Adjust by removing or adding
shims to top swivel pin.
35. When setting is correct remove top swivel bolts, apply
sealant, Part No. STC 50552 to threads of bolts. Refit bolts
and tighten to 65 Nm (48 lbf.ft), and bend over lock tabs.
36. Apply recommended grease between lips of swivel oil seal.
37. Install oil seal, joint washer and retaining plate with 7 bolts
and spring washers. Tighten to 10 Nm (7 lbf.ft).
38. Install tie rod and drag link and secure with new cotter
pins. Tighten fixing to 40 Nm (30 lbf.ft).
39. Install brake disc shield.
40. Loosely install lock stop bolt and nut.
41. Apply a recommended grease between lips of swivel
housing oil seal.
42. Secure oil seal with retaining plate and securing bolts.
43. Install track-rod and drag link and secure with new cotter
pins.
44. Loosely install lock stop bolt for later adjustment.
45. Install brake disc shield. BM52
Post #93947 12th Oct 2011 10:27pm
Sith
Australia
thanks so much guys !!! thissite rocks Knickers , not the best thing in the world ... but right next to the best thing in the world
Post #93965 13th Oct 2011 1:32am
ickle
Or,
Support on axle stands under chassis
remove front wheels,
disconnect track rods
now 'feel' pressure required to turn hub, it should feel reasonable resistance, without hard spots, grunching or tight spots
if its too loose, very easily moved, trolley jack and block of wood under lower swivel pin and just take weight of hub.
remove top two bolts and remove the pin, steadying hub in place, remove smallest shim, refit top pin and torque up.
Remove pressure from jack
Feel hub rotation again, if too slack repeat above and remove another shim, if only big shims are left, add back smaller shims.
Obviously a supply of shims and a vernier caliper help, as does a helper. The jack keeps the hub loaded and stops the grease running out from the seal, a helper can steady the hub to keep the top pin bearing line centralised.
I find if I can rotate the hub with one hand fully built up, it equates to the factory set up without the wiper seals etc in place. I can do both sides in about an hour, on the drive with a trolley jack and air wrench.
Good luck
Keith Thumbs Up
Post #94108 13th Oct 2011 9:32pm
Sith
Australia
Thanks so much Keith ! Thumbs Up
My defender runs oil in the hubs .. so hoping that is of no consequence ? I called past our local stealer and picked up 10 spare shims ... two of each sizing
once angain many thanks Bow down Knickers , not the best thing in the world ... but right next to the best thing in the world
Post #94123 13th Oct 2011 10:56pm
ickle
Try 2 packs of 1 shot grease, I use it in the front of my 100" bitsa running classic range rover axles, so should work happily in a 200 / 300 Defender, better lube in hot climate I would guess also.
Standard fit in all Puma's I think also.
Best of luck, let us know how you get on.
Keith
Post #94297 14th Oct 2011 10:06pm
Sith
Australia
Most people use an oil called Morey's Heavy duty stabilizer in their hubs here ... but if that is what the guard requires then that is what it will be Knickers , not the best thing in the world ... but right next to the best thing in the world
Post #94316 15th Oct 2011 3:19am
Harry.O
Just in the process of re-doing my swivels and replacing the balls to cure an the wobbly steering but I have a query on the torque vales for the upper and lower swivel pin bolts?
BM52's instructions earlier say top bolts 65nm and lower bolts 25nm which matches the values in the Haynes manual and looking at the bolt sizes, feels about right. Looking at my TD5 workshop manual, there is no info on rebuilding the swivels apart from the 300tdi supplementary section. This specifies 78nm for both upper and lower bolts. Can someone kindly confirm for me?
It's a 2005 Td5 110.
Many thanks,
Harry 2005 Td5 110 Hardtop
1989 300Tdi 90 Soft top
1992 200Tdi 90 Truck cab with Land Cruiser axles
Post #675133 2nd Jan 2018 1:20pm
