![]() | Home > Technical > remove tank and parts delivery time in France |
wyvern Member Since: 14 Dec 2009 Location: Cornwall Posts: 2149 ![]() ![]() ![]() |
Hi Nicolas
What year and model of defender 90 do you have ? 200/300 TDI, TD5, Puma 2.4/2.2 or the more modern one? Poppy - TDCI (Puma) 110XS 2.2 - Camper conversion - see the build here - https://www.defender2.net/forum/topic56530.html Elgar -TDCI(Puma) 110XS Dormobile - now sold Devon & Cornwall 4x4 Response - DC126 ![]() |
nicolas0505 Member Since: 23 Dec 2020 Location: briançon Posts: 80 ![]() ![]() |
I have the 90 2.4 from 2007
Co1 Member Since: 19 Aug 2018 Location: North Yorkshire Posts: 3748 ![]() ![]() ![]() |
I can tell you it’s a tough job to drop it. You can but a replacement cradle from YRM, then cut out the old cradle. I could get mine out any other way.
matchap801 Member Since: 05 Aug 2021 Location: Somerset Posts: 120 ![]() ![]() ![]() |
I have a 2009 CSW. The breather pipe on my one was knackered.
I managed to get my fuel tank down enough to change it. 1. Drive it until the fuel light comes on. 2. Remove the fuel filler pipe - wedge some rag in the neck to stop debris falling in. 3. Remove the rear mudguards. 4. Remove the tank guard nuts that come into the Cross member. Then the 4 large bolts securing the tank guard to the chassis brackets. 5. Then using a large tyre lever and crow bar - I managed to force the tank guard forwards so that I could drop it down. Have wooden wedges available. 6. I could drop the tank down far enough to swap over the breather hose for a new one. This whole lot took around 4 hours to remove. An hour to swap the pipe, then 4 hours to refit. If you get a chance, prepare wash it all before, the mud and rubbish dropping down was a challenge. I didn't take photos. Good luck. 2009 Defender 90 CSW 2.4 TDCI. Ex Army Mechanic still living the dream. |
