Home > Puma (Tdci) > Dim dip headlight deactivation...
Cam-Tech-Craig
United Kingdom 2009 Defender 110 Puma 2.4 DCPU Keswick Green
Chaps, I have fitted LED headlamps to my 2010 110 and the headlamps light up with the ignition on in the sidelight position... I'm assuming this is the Dim Dip facility? If so, can it easily be disabled?
Many thanks in advance...
Post #974642 14th Dec 2022 1:46pm
Martin
Site Admin
Welcome to Defender2 Craig, this has been covered many times so do a search and find all you need Smile  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #974645 14th Dec 2022 1:51pm
hank
There are instructions here https://www.landroverexpedition.com/techni...dip-relay/
There are some pics of when I did it in my thread here https://www.defender2.net/forum/topic53240-156.html > 110 XS Double Cab
Post #974736 15th Dec 2022 11:59am
landy andy
Yes easily disabled.
Get the pink relay out and bridge the large two terminals together on the relay holder with a suitable piece of wire with two terminals crimped on it. Thumbs Up
Post #974738 15th Dec 2022 12:10pm
An alternative and probably simpler method is to locate the dim-dip resistor under the front offside wing (midway between the radio aerial and the plastic panel on the wingtop) and unplug the connector from it. Job done.
Post #974749 15th Dec 2022 1:25pm
Cam-Tech-Craig
Bow down Thank you sir... Ill take a look Thumbs Up
Post #975195 20th Dec 2022 12:45am
markb110
I did this, but also bought a replacement plug set, bunged the ends up with Dum Dum then plugged them into the exiting plugs
This way water is kept outbox the open terminals.
Post #975205 20th Dec 2022 8:55am
Cam-Tech-Craig
Managed to buy a new relay on the bay of fleabags for £12... Bow down
Post #976954 7th Jan 2023 1:47am
An expensive solution!
Post #976961 7th Jan 2023 8:51am
