![]() | Home > Maintenance & Modifications > Rear step mounting repairs |
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3638 ![]() ![]() ![]() |
Never used, but my guess is that not need to weld, as needed something similar on a friends 90, but then used flanged nuts. No welding.
But just my guess. If you have long skinny fingers, can manipulate the nut plate inside the crossmember. The outer one is just out of view by the exhaust. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
nitram17 Member Since: 09 Jun 2014 Location: newcastle Posts: 2261 ![]() |
Just my thoughts re drill hole to fit ....put in place from inside crossmember and use washers to to cover
the hole in bulkhead and once you bolt in place the bolt will sandwich the fixing tight and will be secure...... |
JPE Member Since: 19 Nov 2018 Location: South West England Posts: 346 ![]() ![]() ![]() |
When I bought my 110 it had no rear step, just signs of previous step bolts having ripped out.
I bought a rear step from powerfuluk which came with a couple of hexagonal rivnuts. I hammered those in & compressed & they are rock solid. I mention it as i think rivnuts are a good option to consider. |
Francisco Member Since: 25 Sep 2020 Location: Parana Posts: 11 ![]() ![]() ![]() |
Hello
Could someone explain to me what this kit does and how it works? Is it for repairing any damage that the step causes to the plate where it is attached? |
