![]() | Home > My Defender > My Defender |
| Sith Member Since: 10 Oct 2011 Location: Perth W.A Posts: 13
Well she is a 1997 300tdi 110 wagon ....set up for fishing and gold prospecting ....
Mod's so far are .... Winch bar Warn 12000 Lightforce xgt Stinger uhf aerial IPF Lighting upgrade Kings springs Bilstien shocks Terrafirrma shock mounts and relocation cones Troutbeck protection duel batteries 750 GME inverter Glind shower Frontrunner gull wing Tracklander rack Mulgo rear ladder Frontrunner bbq rear wheel mounted unit HID rear work lights 60LT engel Polaris awning and sides TAIT 20w uhf Front and rear lockers Maxi drive axles rear draw system 60lt water tank with shurflow pump upper roof line cargo netting 4x jerry cans and holder roof rack mounted front runner side mounted table system Mods to come: SECOND GULL WING RE TINT WINDOWS UP REAR SPRINGS RATE COBB OVEN Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated |
| LESVOSD110 Member Since: 19 Aug 2009 Location: South Africa Posts: 241
Welcome and you have a cool setup there. Puma 110 SW
90 V8 SOFT TOP |
| GREENI Member Since: 22 Aug 2010 Location: staffs Posts: 10387
Nice camp set up, loving the window conversion that opens
I like the HF/VHF antenna too |
| Theater Member Since: 27 Sep 2010 Location: Pisa Italy Posts: 514
Welcome !!!
Very Nice Defender 110 "SW" SE Galway Green MY 2009 Ex Defender 90 "SW" S Santorini Black MY 2010 |
thanks guys ...
in answer to above ... The Gull wing window is from Frontrunner 4x4 in SA , and I am saving for the otherside That "porta loo" is actually a bin The antena is called a STINGER and is a uhf hi output and goes with my uhf unit which is 20w instead of the 5w that the shops sell . I have her going in this coming Monday for the timing belt as she has just clocked over 220km anbd i need the pre load set on the front left hub as it has just started to shake around a bit |
| Spencer72 Member Since: 29 Oct 2013 Location: Western Australia Posts: 5
Hi Sith, hopefully you check your messages. I see you have the Tracklander roof rack. I have a 110 and considering the Tracklander as an option. If possible can you send some photos from side and give us some feedback on how it works with yours. Do the legs scratch on the side of the roof window, width/length etc?
| GUM97 Member Since: 05 Feb 2012 Location: Cheshire Posts: 3555
Lovely vehicle!
"Land Rover- Proudly turning drivers into mechanics since 1948" ![]() |
| jimbob7 Member Since: 06 Jul 2013 Location: uk Posts: 2055 |
Moar pics
| sweepc Member Since: 19 Jun 2011 Location: uk Posts: 568
Very nice setup. I like
| charliebaja Member Since: 05 Aug 2013 Location: Surrey Posts: 211
I am guessing that you have small clips on the side of the wing, above the wheel arch that enables you to clip the table top to and the leg that holds it up, just sits in the inside of the wheel, enabling it to always sit at the right height? |
| Leenorthants Member Since: 08 Sep 2013 Location: Silverstone(ish) Posts: 861
It's a front runneR tabler, check them on ebay |
| CR Member Since: 28 Jan 2010 Location: Ireland Posts: 947
wow camping on the beach looks amazing
| All times are GMT |
