![]() | Home > Td5 > TD5 - AC upgrade - Grill upgrade required? |
Penfold_6290 Member Since: 22 Sep 2021 Location: Dorset Posts: 399 ![]() ![]() ![]() |
Have you bought this kit?
https://www.lrparts.net/da2342l-land-rover...tment.html The description says that an extended nose cone is not required so you should be fine. When I added AC to my Td5 I used genuine parts from various different sources so I did opt to change the nose cone assembly...no point in having AC and not letting other Defender drivers know you've got it right? ![]() |
doruk1981 Member Since: 15 Aug 2022 Location: Aargau Posts: 101 ![]() ![]() ![]() |
Yes Exactly this one. I had noted the comment on the condenser unit. But its alway good to check what the experiences of fellow owners is / was with the builds. Nothing more cumbersome than starting to plug in everything to realize that I forgot something ... given I'm based in Switzerland, every additional order results in one additional week of delay / waiting time
On another note: its interesting that the same Kit has an online price range of 2.6k to 3.6k pound ... Td5 110 Station |
I guess the price variation comes from some sites displaying prices including UK VAT (20%) and some don't.
4RF RDS Member Since: 19 Jul 2015 Location: Ottawa Posts: 987 ![]() ![]() ![]() |
Having the AC front grill “bump out” part is easiest. You can install AC using the regular grill but there will be a lot of messing about. Its just easier.
Good luck (you’ll really enjoy having the AC plus the benefit of a quieter ride with the windows and vents closed) 2010 Range Rover MkIII Autobiography Super Charged (Idris) 2003 Range Rover Mk III (Desmond FitzWilliam) 2000 Defender 110 CSW TD5 (CTX) 1992 Range Rover Classic (Lizzy) 1972 Series III 300 Tdi (Stanwood) 1967 MGB GT Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats. H. L. Mencken (1880 - 1956) |
Thanks!
I'll order one just in case along the other parts ... prefer safe to sorry and pay double shipping and time along the way ... Td5 110 Station |
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3600 ![]() ![]() ![]() |
Remember that you need the lower AC grill with the surround. There are also 2 brackets (plus screws and spire nut plates) but these last are easy to get and make.
The original AC grille that fits in the lower part of the surround is aluminum, but goes powdery in short time. The aftermarket stainless steel are better quality. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
