Home > Maintenance & Modifications > is it just plain fiddly or is there a tool ?
how the heck do you attach a grease gun (with a flexi hose) to a right angle prop grease nipple ?
is there a tool ?
do I need to move the nipple around a bit ?
its not a problem on the rear prop - just the front one - did I miss something ?
Post #93428 9th Oct 2011 5:32pm
Matt
United Kingdom 2015 Defender 90 Puma 2.2 XS CSW Corris Grey
You either need to get a spanner on the grease nipple to rotate it a fraction or sometimes i find that fileing the sides of the grease gun end down a little to create 2 flat edges, will enable it to fit in easier. Thumbs Up
The other way is to change the grease nipple for one thats has say a 45 degree angle instead of a 90. As its only on one prop try rotating the prop shaft round a little to see if in a certain position you can get on it Thumbs Up 15 plate 2.2SW XS
Post #93437 9th Oct 2011 6:18pm
AndrewS
Rotate the prop so the nipple is at the top of the rotation Thumbs Up 130's have feeling's as well you know Smile
Post #93439 9th Oct 2011 6:22pm
bob neville
Join the club Steve Thumbs Up
I posted on another thread about the exact same problem and somebody suggested the UJ's may have been installed incorrectly.
I have tried rotating the prop, grinding flats on the connector - nothing.
I am going to drop my front prop to see if I can grease it off the vehicle.
Bob
Post #93444 9th Oct 2011 6:41pm
glad it was not just me Thumbs Up
cheers guys, i'm going to try and turn the nipple around a bit and see if it will fit.
i've also googled it and found some angled ends ... see if screwfix, machine mart or other tool shop sell them, I can only find them in Auz at the moment Shocked - I'll keep you posted
this is the sort of thing I think we need
http://etoolpros.com/automotive-tools/TXN-418.html
Post #93449 9th Oct 2011 7:02pm
bob neville
Not that I have been looking at the same thing Thumbs Up
http://www.thenippleshop.co.uk/acatalog/St...egree.html
Quite a few places sell them (we don't !)
Bob
Post #93453 9th Oct 2011 7:29pm
I must admin Bob, when I saw the URL I did a double take Rolling with laughter I was going to ask you cheekily if your buyers could make some calls Thumbs Up
I'll do some more research tomorrow and pop you an email.
this is the sort of thing we need
cheers
steve
Post #93455 9th Oct 2011 7:36pm
bob neville
I found that exact thing yesterday on sale in the UK when looking for a decent grease gun.
Just got to find it again Thumbs Up
Bob
Post #93470 9th Oct 2011 8:20pm
bob neville
Item SHCR about half way down the page.
http://www.stephenslube.co.uk/grease_guns.asp
Bob
Post #93473 9th Oct 2011 8:25pm
K9F
Am I missing something here? I finished greasing my propshafts just yesterday morning (ran out of grease Friday) and my nipples are straight! Couldn't have been done at all during service as they were coated in Waxoyl and required quite a lot of grease!
On my Disco I had to grind down the head of the gun to get it to fit because the nipples were between the UJs with very limited access. If you go through life with your head in the sand....all people will see is an ar5e!!
Post #93477 9th Oct 2011 9:07pm
good man Bob - you found it... will call tomorrow and order a couple ... shall i order you one too ?
Post #93480 9th Oct 2011 9:20pm
bob neville
It's OK Steve, I will be ordering some other stuff from them later this week.
Bob
Post #93503 10th Oct 2011 7:08am
Ordered a couple of ends from "stephenslube" arrived 1 day later - how's that for good service.
Post #93814 12th Oct 2011 7:20am
Happyoldgit
This thread prompted me to do a pre winter lube. I've got a fine nosed flexi and can generally manage to get it on the 45's in the front prop. What ends did you order?
Interesting to note by the undisturbed wax that none of mine were touched during its 1st service either, oh and I found both the front prop to pinion flange and rear prop to output flange joint nuts and bolts were not tight Rolling Eyes Steve.
http://forums.lr4x4.com
Post #93885 12th Oct 2011 5:52pm
hi MOG
I ordered a couple of these ones ...
Standard hydraulic-90 degree slotted-for confined spaces.
Post #93890 12th Oct 2011 6:08pm
