![]() | Home > Puma (Tdci) > What Part Is This??? |
TriniDaddy Member Since: 23 Nov 2020 Location: 10.57422, -61.28906 Posts: 40 ![]() ![]() |
Can anyone identify this part? I'm trying to locate it on LRworkshop but nothing definitive. Thought it was the fuel cooler but that doesn't seem to be it. Could be this other thing in the diagram but it's not labeled at all!
There's wires attached (one broken as you can see) and I'm getting the check engine light (which to be fair comes and goes every so often) but I'm starting to think it might be connected. Appreciate any insights. ![]() Click image to enlarge ![]() Click image to enlarge 110 SW 2.4 IZUMI BLUE |
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3601 ![]() ![]() ![]() |
Found this, which looks so similar, and would confirm that is a fuel pump.
https://www.amazon.com/Universal-Electric-...B07Z7D2DK5 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
Spot on!
It really doesn't correspond with anything in the diagrams or manual. Will just clean it up, tack it onto the chassis and reconnect it and hope for the best. Thing is the car works fine. Can't think of a reason that would be installed in the first place but really not interested in getting forensic on this one as I have some suspension bits to work on. Hopefully all will be well. Thank you. 110 SW 2.4 IZUMI BLUE |
