Home > Off Topic > small generator anyone use one
Stacey007
Hello
Looking at a small generator around 2KW,
this type of thing, LPG also would be better but understand these are a lot more?
https://www.machinemart.co.uk/p/clarke-ig2...generator/
Anyone recommend one?
Post #970435 8th Nov 2022 9:17pm
Dinnu
Depends on your use. I find the inverter type generators sensitive circuitry fragile when it comes to using power tools like angle grinders, drillers and the like.
Good for running other equipment especially if it is a pure sine wave. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #970452 9th Nov 2022 4:47am
ibexman
I had a robin generator for years no problems at all , I find when buying this type of equipment buy the best you can for your money I’d go hor a Honda or similar Thumbs Up
Post #970459 9th Nov 2022 9:35am
Rashers
If you do buy a petrol generator, use an additive (like ethanol shield) with the fuel as there is nothing worse than needing the generator to start, and the petrol has gone off.
I would recommend anything with a Honda engine.
The more you pay, the better the quality. I’m not knocking Machinemart, and I have lot’s of Clarke equipment but it is built to a price. Saying that, I have seen plenty of market traders using Clarke Generators. It’s not all bad.
Post #970500 9th Nov 2022 3:08pm
Landymatt
i used to use a cheapo 2-stroke genny and it was awful, forever not running right and needing attention.
Got a Honda eu2200i and it’s been absolutely perfect. But they are expensive!
Post #970581 10th Nov 2022 8:15am
discomog
I would second Landymatt's suggestion of the Honda eu2200i, superb quality and with the benefit of the ultra reliable Honda engine. I know they are pricey and if looking at something a little less expensive then I would take a look at the Hyundai HY2000Si. Defender 90XS SW
Mini Countryman Cooper S
Morgan Plus 8
Post #970594 10th Nov 2022 9:14am
Jabberwocky
Luxembourg
Depending on usage have you considered a solar generator/power station? I use one to power my camper and it can be charged by AC, DC or Solar. Various battery and inverter sizes, no noise, no fuel to mess about with.
Post #970716 11th Nov 2022 3:00am
Intercept
United Kingdom 2002 Defender 110 Td5 Black LE Java Black
I have one of these for portable mains power. It gets used for pumps, power tools, iPads/phones etc. Sure, it won't deliver 2Kw all day like a petrol generator, but it's virtually silent apart from the cooling fan and recharges very rapidly from 240Vac, and less rapidly from DC/solar sources.
https://uk.ecoflow.com/products/delta-2-portable-power-station
Larger capacity versions are available but this one ticked my boxes.
Post #970752 11th Nov 2022 2:23pm
geobloke
Yeah I have been looking at a Jackery solar setup recently - https://www.jackery.com - Heard excellent things about them
Post #970753 11th Nov 2022 2:37pm
Jabberwocky
Luxembourg
Jackery are the paid influencers power bank of choice.
They threw money at YouTubers to plug their products and it worked for a while, there are much better options out there.
Post #970994 13th Nov 2022 6:29pm
Rescue01
I prefer Bluetti myself better battery technology.
Post #971032 13th Nov 2022 9:47pm
cyberhusky
Luxembourg
I just received my Bluetti EB3A yesterday. I intend to use it for my Domestic fridge in the Def.
I wanted the bigger 70 model, as it was on sale at local tools markets but I thought if they do have it, there will soon be a newer model with better functionality.
Bluetti do use LiFePO4 batteries. They do last much longer than EcoFlows Li batteries: 2500 charging cycles vs 800! 22MY Defender 110 (actual) | 10MY Freelander 2 (history) | 15MY Discovery Sport HSE (history)
Post #974146 10th Dec 2022 1:28pm
Landymatt
Interesting re these other makes being superior to the Jackery which I’d assumed were the leaders.
Looks like ecoflow do use those fancy batteries too.. this was in the link that was posted above -
“Built to last 6x longer - Get 10 years of daily use until hitting 80% of its original capacity. That’s down to its LFP battery chemistry giving you 3000+ cycles.“
Post #974175 10th Dec 2022 6:05pm
miker
Some of ecoflow's models are LiFePO4, but some are standard Li-Ion.
Post #974186 10th Dec 2022 7:03pm
cyberhusky
Luxembourg
Yes on the expensive ones. The smaller models I checked not. So I decided to go to the smallest Bluetti.
I wanted the EB70 but it doesn't have the advanced features of the other models so I went for the smallest model EB3A which I think is enough for my needs. A friend of mine has the EB70 in his old Defender 110 and he told me that's enough for 3 days for 4 users when overlanding.
(fridge, smartphones, laptop)
I will upgrade when the successor of the EB70 comes.
As for EcoFlow their build quality seems to be better and the design is better too, though Bluetti isn't bad.
For Spring I will buy a 200W solarpanel. 22MY Defender 110 (actual) | 10MY Freelander 2 (history) | 15MY Discovery Sport HSE (history)
Post #974242 11th Dec 2022 2:51pm
