![]() | Home > Puma (Tdci) > which holes do factory tow eyes go into? (D90 photo request) |
Tardis Member Since: 24 Nov 2017 Location: Hannover Posts: 22 ![]() ![]() ![]() |
These ones?
RobKeay Member Since: 19 Jul 2009 Location: Stafford Posts: 1596 ![]() ![]() ![]() |
Just being pedantic, but they aren’t towing eyes. There just put on as tie down points during transportation.
LR90XS2011 Member Since: 05 Apr 2011 Location: bickenhill Posts: 3677 ![]() ![]() ![]() |
its the same place as my Jate rings bottom of the chassis at the front
![]() Click image to enlarge ![]() Click image to enlarge DEFENDER 90 TDCI XS, I hope everyone is well and your land rovers make you happy |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20951 ![]() ![]() |
Those are indeed lashing points for transport and not ideal as a towing point.
If they have excessive shock load on them the fixing could tear the chassis hole open a little. Elongating the chassis hole, and the fixings aren’t overly robust either. I seem to remember they were used for transport when built new, and also harks back to military use and cargo lashing points for transportation in aircraft etc with the army and with helicopters and things like that. I have them on mine but they are bolted flat against the surface, so present but not used at all. The same thing applies with Jate rings too, though they can be useful I’d consider them a light duty securing point and not suitable for recovery use. ____\We|Will|Win/___ ____/🇬🇧🇺🇸\____ _//*⛽️🛢️⚙️🧰*\\_ |
Gasket Member Since: 30 May 2020 Location: Manchester Posts: 629 ![]() |
Thanks all! That’s the front sorted, just need a pic of the rear now of anyone has a pic.
discomog Member Since: 09 May 2015 Location: Notts/Lincs Border Posts: 2541 ![]() ![]() ![]() |
Rear lashing point (r/h side) 90 puma
![]() Click image to enlarge Defender 90XS SW Mini Countryman Cooper S Morgan Plus 8 |
That’s perfect - thanks buddy!
Right folks - that’s me done, thank you all for your help! |
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3601 ![]() ![]() ![]() |
I you want to have originality. You will need to drop the fuel tank as the bolt for the rear lashing point goes from the ‘inside’ and nut is against the lashing point itself. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Thanks Dunnu. I’m an idiot! I just looked again under the back of the 90 and realised that I left the bolt in place for exactly that reason: I had just undone the nut, removed the eye and then tightened up the nut again.
That’s why I couldn’t see an obvious hole to reattach the eye. Thank you! |
Glad you are sorted.
![]() 2012 90 CSW, 2.2TDCI, Santorini Black |
