![]() | Home > In Car Electronics > Solar MPPT controller - who's fixed it where? |
donmacn Member Since: 07 Nov 2017 Location: Nth Scotland Posts: 1910 ![]() ![]() |
Hi folks,
I have a 300Tdi, so the 'battery box' is the compartment under the passenger seat. I'm considering a portable/suitcase type solar system as an 'off grid' top-up option if needed, mainly to run a fridge and keep the beer cool. I understand that an MPPT controller is the thing to use - more efficient panel output - but when looking into one brand it said something along the lines of: the controller will turn unused charge/current into heat, and that it should be mounted in a well-ventilated area with 9" of clearance all round. I had been hoping to fit this into the battery box, but with two batteries it's a little cramped in there. I might find space to fit the controller (they're a bit bigger than I anticipated) but I certainly won't find the 9" clearance, and it's not especially well ventilated. On the other hand the box is a YRM alu. version, and aluminium is a good heat sink. So for those who've done this, where have you put the controller? If in the seat box has it survived/suffered? I usually try and search first, and did this time, but couldn't find any info. ta. Donald 1994 Defender 300Tdi 110 SW - owned since 2002 - 230k miles and going strong (The 'rolling restoration' or tinkering thread: http://www.defender2.net/forum/topic58538.html ) 2000 Range Rover P38 4.0L V8 in the past.. RR classic - fitted with 200Tdi 1984 RR classic - V8 with ZF auto box 1993 Discovery 300Tdi not to mention the minis and the Type 2 VW camper... |
Hi Bill,
Thanks for that - that's even more cramped than mine! Your batteries are a bit larger, but against my transmission tunnel I have my accessory relay and fuse installation. Is yours a mppt controller? Have you had no issues with heat generation? Donald 1994 Defender 300Tdi 110 SW - owned since 2002 - 230k miles and going strong (The 'rolling restoration' or tinkering thread: http://www.defender2.net/forum/topic58538.html ) 2000 Range Rover P38 4.0L V8 in the past.. RR classic - fitted with 200Tdi 1984 RR classic - V8 with ZF auto box 1993 Discovery 300Tdi not to mention the minis and the Type 2 VW camper... |
Bill1919 Member Since: 04 Mar 2017 Location: Dorset Posts: 59 ![]() ![]() ![]() |
Yes, it is a CTEX DC-DC MPPT controller. I fitted it about 3 years ago, no problems with heat. 1988 110 csw 2.5Td (19J) (gone)
1992 110 csw Tdi200 (gone) 1995 110 csw Tdi300 (gone) 2015 110 XS csw 2.2 puma |
Curious to know. What does MPPT stand for?
Maximum Power Point Tracking. Basically, solar panel output varies with temperature and these controllers make the best of what's available, giving an advantage of approx. 25-30% over earlier controller types. Darren
LRA you are indeed an anorak, but definitely my kind of anorak ![]() ![]() |
^^ I knew that too! Does that make me an apprentice anorak??
Thanks Bill - I guess it's a case of manufacturers covering themselves. Donald 1994 Defender 300Tdi 110 SW - owned since 2002 - 230k miles and going strong (The 'rolling restoration' or tinkering thread: http://www.defender2.net/forum/topic58538.html ) 2000 Range Rover P38 4.0L V8 in the past.. RR classic - fitted with 200Tdi 1984 RR classic - V8 with ZF auto box 1993 Discovery 300Tdi not to mention the minis and the Type 2 VW camper... |
Donald I do feel your signature now requires the addition of the post-nominal A-A
![]() A-A (Apprentice Anorak) |
Julie Member Since: 07 Oct 2017 Location: La Réunion, Madagascar Posts: 589 ![]() ![]() ![]() |
Yeah. 1x John Deere 110 amp batt 1x AMG 100 amp And that CTEC charger fit all well in my battery box And one cable coming out connecting the 120 W foldable solar panel adjustable towards sun light. 1st Installation takes about 90 min. Just mind all the required fuses ! |
