Home > Td5 > Front row underseat storage?
phillips321
2005 Defender 110 2.5 TD DCPU Belize Green
Hi chaps,
Am replacing my cubbybox with a middle seat so wanted to know if there is an easy way to store stuff underneath? The metal trays that block access to the gearbox, battery and ECU look like they could be modified to add a recess so that bit can be stored in there?
Has anyone done this?
Thanks in advance
Post #966852 6th Oct 2022 11:05am
excossack
There is this option
https://yrmit.co.uk/product/lt77-r380-cent...-defender/
with some DIY you could make it usable space 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #966858 6th Oct 2022 11:49am
rallysteve
There is also this storage which lifts the cubby box https://www.mudstuff.co.uk/collections/int...485209685. You could fit one of those YRM trays (which i use in both my LRs as a location for aux electricals) and fit one of the Mud stuff ones on top. If you make the Mud-Stuff one have a removable base panel then you could access the YRM tray beneath without having to remove the cubby box (this is my annoyance with my current setup)
Cheers,
Post #966865 6th Oct 2022 12:16pm
