![]() | Home > Puma (Tdci) > Rear crossmember torx/flanged bolts and washers - outers |
DSC-off Member Since: 16 Oct 2014 Location: North East Posts: 1491 ![]() ![]() ![]() |
2015 MY definitely has hex head bolts.
Mine are due for a change, have some front bumper bolts and washers in stock that appear to be the exact same parts. I haven't got round to fitting them yet, the crossmember needs a coat of paint first. |
macfrank Member Since: 05 Nov 2015 Location: somewhere in the north Posts: 1124 ![]() ![]() ![]() |
On my MY2015, too, it's the hex flanged bolt from the pictures.
From memory/pictures it could indeed be the same as the M10x110 used for the bumper: https://www.lrworkshop.com/diagrams/land-r...es_44907#3 In this "2007-2016" diagram https://www.lrworkshop.com/diagrams/land-r...eats_45090 it's still listed as Torx. |
Gasket Member Since: 30 May 2020 Location: Manchester Posts: 629 ![]() |
Thanks both. That’s good to know and thanks for the links.
Alas I can’t find 120mm flanged bolts in A4 either. However, scouring through my parts box did yield a set of four 120mm basic hex bolts in A4: so guess I’ll have to live without the flange. I’m short of the washers of the right size though and they look to be bigger than basic M10 repair washers so will have to try and guess the OD and pick some up next week. My local place has them in 25mm, 30mm and 40mm OD if anyone has time to have a measure. |
