Home > Puma (Tdci) > Help: can't get bulkhead mat out around pedals |
Gasket Member Since: 30 May 2020 Location: Manchester Posts: 629 |
Hang on… might have sussed it.
Looking at this diagram: https://www.lrworkshop.com/diagrams/land-r...al_45160#1 I think I might just need to remove the two screws (marked as number 11). But I haven’t seen these - perhaps they’re accessed through the fuse box panel. Assume I’d still need to remove the bonnet cable handle too though. |
27th Sep 2022 9:58pm |
Updating my own Q post here, but might be of use to someone.
Found that the black plastic cover over the stoplamp switches isn't attached by any screws, there's just four plastic tabs to release. See this picture: Click image to enlarge Then in DGardel's very useful copy of the workshop manual, page 963 and page 178 it gives instructions on disconnecting the switches to release the matting. I'll give it a go tonight and will report back. |
28th Sep 2022 1:38pm |
Caterham Member Since: 06 Nov 2008 Location: Birmingham Posts: 6260 |
good luck. |
28th Sep 2022 5:40pm |
Sorted - the cover just unclips and exposes the switches which can be unscrewed. The rest is obvious.
The cover had felt really flimsy but well attached and I didn't want to pry it out and risk breaking it. Luckily the photos above show where the tabs are and its then pretty easy to do. Phew! |
29th Sep 2022 9:06am |
