Home > Puma (Tdci) > Size of front caliper bleed nipple on 2010MY Puma
kmac
Just tried to bleed my brakes and cannot open the front caliper nipple as seems to be between 11mm and 12mm so guessing an imperial size spanner is needed? Or is it 11mm and just covered in gunk?
Post #965722 22nd Sep 2022 4:22pm
landy andy
11mm Thumbs Up
Post #965725 22nd Sep 2022 4:34pm
landy andy
If Censored use a socket as it has better purchase on all sides, then when cracked, use spanner.
Post #965726 22nd Sep 2022 4:35pm
kmac
may have to move the ABS sensor to use a socket
thanks for the info though
Post #965728 22nd Sep 2022 4:40pm
7/16" AF should also fit, as it is very similar in size to 11mm.
Post #965736 22nd Sep 2022 5:43pm
