Home > Puma (Tdci) > Another propshaft question
piechipsandpeas
Australia 2013 Defender 110 Puma 2.2 SW Indus Silver
I'm going to be removing the transfer case soon so whilst the prop shafts are off I'd like to grease the sliding joints. On a Puma Defender the propshafts don't have the grease nipple for the sliding joint so I'm planning to separate the shaft and grease the joint.
My question is - Is it just a case of removing the rubber gaiter and sliding the two halves apart or is there more to it than that?
Post #963496 31st Aug 2022 12:34pm
jst
You can do as you suggest just make sure it goes back together in the same sines and is fitted the same way around. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #963577 31st Aug 2022 8:06pm
piechipsandpeas
Thanks JST
Post #963613 1st Sep 2022 5:23am
