Home > Maintenance & Modifications > Snow Chains for 285/75/16 MT's
nickh90
England 1989 Defender 90 V8 Petrol SW Auto Java Black
Hi all,
I have pressed search and i have googled and i have read lots of info.. all very useful but a little inconclusive!
I run a defender 300tdi with 5" lift, 285 75 MT's and 2 lockers - so chains are more handy after a few days and we have the polished stuff to get around on.
For a few reasons this year (mostly ice related and the roads where i now live) i would like the option of chains for my defender... it seems i can get some for £50 or for £500 per axle. Where actually they all look quite similar and are designed to do the job. SO, what should i get?
I do spend some time recovering people (or did last year) and helping out the local emergency services and local community, ambulance and care homes
Mrs due late Nov for baby no.1 - i am not letting any snow stop us getting to the hospital
Live in rural and hilly area with one main road then lots of B's and lanes
All seem to have similar design and 16mm links, so what are the differences?
What should i buy?
Nick
Post #92366 3rd Oct 2011 9:45am
I have a set (four) of heavy duty Pewags from Devon 4x4 for the 285/75 x 16 MTs on my Defender, and have been completely satisfied with them. I also have a set (four) of heavy-duty RUDs for the 7.50 x 16 MTs on my Series 1 and have been equally satisifed with them.
My recommendation would be any reputable make (i.e., Pewag or Rudd) of basket-pattern chain designed for light commercial vehicles.
Cheap chains are like any cheap tool - more expensive and dangerous in the long run.
Post #92378 3rd Oct 2011 10:54am
leeds
If you want Pewag snow chains I strongly recommend that you google the snow chain shop. Run by Brindleys. They carry a wide range of Pewags and do next day delivery and prices are more reasonable then elsewhere.
Brendan
Post #92380 3rd Oct 2011 11:13am
mick
England 2010 Defender 130 Puma 2.4 HCPU Rimini Red
I got a set of 4 from Brindley chains and they are quality gear Thumbs Up
Post #92520 3rd Oct 2011 10:29pm
AndrewS
What Leeds and Mick say Thumbs Up 130's have feeling's as well you know Smile
Post #92522 3rd Oct 2011 10:30pm
pouf
Greece 2009 Defender 110 Puma 2.4 SW Zermatt Silver
by the way.............
is it necessary to use wheel spacers with 285/75/16 tyres?
i heard you can't turn,is it true? www.newfoundland.gr
Post #93192 7th Oct 2011 8:42pm
With 30mm spacers your turning circle will be the same.
Post #93213 7th Oct 2011 10:39pm
pouf
so, it is needed only 30mm spacer,no 55mm or more.
thanks a lot blackwolf Thumbs Up www.newfoundland.gr
Post #93342 9th Oct 2011 8:07am
AndrewS
No spacers are not required Thumbs Up 130's have feeling's as well you know Smile
Post #93381 9th Oct 2011 1:03pm
pouf
with all rims or it is needed a specific one? www.newfoundland.gr
Post #93457 9th Oct 2011 7:43pm
AndrewS
From personal experience Boosts, ZU's and Terrafirma wheels don't require spacers with 285's 130's have feeling's as well you know Smile
Post #93474 9th Oct 2011 8:26pm
pouf
interesting andrew !!!!!!!!
thanks a lot Thumbs Up www.newfoundland.gr
Post #93490 9th Oct 2011 10:59pm
With 285/75 KL71's on standard Boost alloys without spacers on my 110 my turning circle was adversely affected. The vehicle was completely drivable but you had to bear in mind that the manoeuverability was affected.
With the above wheels and tyres on 30mm spacers the lockstops do not need adjusting from the standard settings and the turning circle is standard.
So with 285's on Boost alloys you do not need spacers but they will restore the original turning circle and make life easier.
285's are of course wider than the recommended max width for a Boost, so if you change the rim then buy one with an appropriate offset and dispense with the spacer. However, I have run 285's on Boosts for a lot of miles and had no problems with them.
Post #93522 10th Oct 2011 10:34am
