Home > For Sale & Wanted > [Wanted] Webasto / aux heater fuel take off/pickup TD5
benspray
United Kingdom 2006 Defender 130 Td5 HCPU Chawton White
Hi all
Long shot but does anyone have the parts needed to add a fuel pickup to the little stub on the stock Defender TD5 fuel pump kicking around in their stock that they'd be willing to sell?
Pretty sure it was the same bits for Discoveries as well as Defenders (JEI100030 as far as I can tell)
Found these photos from another post to show what I'm looking for, (not sure which if either is genuine?) seems its just the rubber elbow and that you use the stock webasto 2mm ID fuel tubing as the pickup/
I'm trying to avoid dropping the tank on my 130 just to measure up and then trying to then find something on ebay etc to bodge something up from.
I've looked at the inline filler pipe type but not convinced they'll fit a 130 nicely as there doesn't seem to be that much of straight section on the 130 filler hose
Ben
Post #962134 18th Aug 2022 2:52pm
benspray
Failing that if anyone happens to have a TD5 pump kicking around either for sale that I can then play with off vehicle, or is willing to measure the OD and ID of that fuel take off stub Smile
Cheers all
Post #962137 18th Aug 2022 2:58pm
camelman
Fit one of these, saves dropping your tank or messing with the pump
I have one on my 130
https://www.ebay.co.uk/p/647045231
Post #962155 18th Aug 2022 6:40pm
rallysteve
Cheers all
I have been after a busted td5 pump for ages just for the plastic strainer on the bottom to replace the cracked on on mine. Happy to go halves on a rough fuel pump off ebay if you are interested? Thumbs Up
Post #962166 18th Aug 2022 7:26pm
Matt110
I would second that for sure.
It's super fast to fit, means you have easy access to it in the future, and just works. Just make sure you double jubilee clip each end of it to make sure it's nice and secure.
Made me feel better anyway.
Post #962167 18th Aug 2022 7:34pm
benspray
Thanks, don't suppose you could grab a photo of it fitted on your 130 could you if you get a mo Smile
I wasn't sure how much straight section they needed but didn't seem to be much space on a 130 filler.
Thanks
Ben
Post #962200 18th Aug 2022 11:19pm
benspray
rallysteve wrote:
Cheers all
Steve
Cool will let you know if I go that route with it, interested to see how well the fuel filler/inline ones work now.
Post #962201 18th Aug 2022 11:20pm
s55shh
Cheers all
I've got one of these on my 2015 110 USW
Post #962329 20th Aug 2022 3:16pm
benspray
Ordered one of the fuel filler inline style take offs, hope it fits a 130 filler hose Wink
Post #962458 22nd Aug 2022 12:19am
