![]() | Home > Maintenance & Modifications > Puma Front ABS Sensor |
Screbble Member Since: 26 Apr 2015 Location: Lancashire Posts: 2274 ![]() ![]() ![]() |
I suppose they ‘could’ work loose depending on how ‘good’ the copper housing is in terms of retaining it.
I’ve taken a quick photo of mine which might give you an idea of depth when fully seated. They should push it to a fairly noticeable ‘stop.’ Did your ABS light register any fault? ![]() Click image to enlarge |
Bluest Member Since: 23 Apr 2016 Location: Lancashire Posts: 4316 ![]() ![]() ![]() |
The fault code I've been getting is "18-07, front left sensor electrical failure". It causes the
brake and TC warning lights to show, but it has only been occuring about 50% of occasions I drive the car. Its been occurring for the last couple of months. Hopefully pushing it back fully home will resolve things. 2007 110 TDCi Station Wagon XS |
Balvaig Member Since: 19 Feb 2016 Location: Fife Posts: 736 ![]() ![]() ![]() |
The workshop manual for 2012 on requires a new sensor bush to be fitted after removal of the sensor. Refitting is by applying anti seize grease and pushing fully home.
Although I’ve been suffering with ‘other’ ABS issues, I have in the past found that ‘reseating’ an ABS sensor only a few millimetres has solved the problem so fingers crossed you’ve done the trick
![]() Just in case you haven’t seen it, this is the copper retaining bush they are seated in: ![]() Click image to enlarge Hope your lights remain out! |
v8bob Member Since: 14 Mar 2018 Location: Midlands Posts: 342 ![]() ![]() ![]() |
My RH front had an intermittent fault for a while. I found it was a loose plug connection on the inner front wing. The front wheel sensor has a shortish wire and this then connects to the loom. This has a 2 pin/socket joint. I just had to squeeze the 2 socket parts a little.
Quick update, done a touch over 300 miles since pushing the sensor back in and the fault has not recurred. Hopefully that's all there was to it.
Thanks for the info on it being in a sleeve. Always good to know how it goes together. 2007 110 TDCi Station Wagon XS |
Good news
![]() It’s often a simple fix. My 3 amigos haven’t come back (separate ABS issue). Cheers Will |
