![]() | Home > Expedition & Overland > Expedition Roof Rack Repair |
Bluest Member Since: 23 Apr 2016 Location: Lancashire Posts: 4338 ![]() ![]() ![]() |
In my experience, you are on a hiding to nothing trying to repair it piecemeal. It is very likely that any corrosion has crept a reasonable distance beyond just the area you can see suffering. I'd be looking to have the whole thing blasted and re-coated. Whether that is economic or not I don't know. 2007 110 TDCi Station Wagon XS
NDF Member Since: 09 Dec 2018 Location: England Posts: 20 ![]() ![]() ![]() |
Agree, corrosion will almost certainly have spread under the paint. I removed the offending sections (taking it back to good paint at a junction of members), wire brushed and gave it a few coats of Buzzweld CIO, making sure to concentrate on where the old finish ends to help stop creep. I am sure it will be a temp fix, but has lasted a couple of years and looks surprising good. Would be tempted to use CIO if/when I do the whole thing.
Given how a LR chassis rots I also gave the inside of the roof rack a good dose of Corrosion Block (a thicker version of ACF50) |
sako243 Member Since: 08 Jul 2014 Location: Wales Posts: 1250 ![]() ![]() ![]() |
Depends on the abuse the roof rack may see sliding things and off but I'd personally avoid CIO. I and a couple of others have tried it on galv, bare steel, rusted steel, primed, varying temperatures and whilst easy to apply and looks good initially it hasn't held up to what I'd call fairly typical Defender use. In fact the factory paint from 1994 has held up where its still on better.
![]() 82 Hotspur Sandringham 6x6 95 Defender 110 300Tdi |
jimbo55 Member Since: 15 Jul 2020 Location: Midlands Posts: 408 ![]() ![]() |
In my opinion it’s a bit of an all or nothing situation, you either strip the whole lot and repair it all and paint it or do nothing. Just doing the bits you can see will do nothing in the grand scheme of things. But be warned, what you see will be nothing when you see the whole lot. They are very prone to rusting out.
Their agree with Sako and avoid CIO, it’s not the best product and gets raved about because someone got Facebook famous for basically rebranding corroless products for automotive use instead of on oil rigs which have significantly different environments to be used in.. In Craig’s defence though his galv in one stuff is a massive improving over chassis in one and does hold up much better on a Land Rover (regardless of if it’s galv or not) so |
