Home > Maintenance & Modifications > sump guard with winch
Dean Watson
United Kingdom 2011 Defender 110 Puma 2.4 XS DCPU Stornoway Grey
hi
Anyone know if a sump guard can be used with a winch bumper?, they both seem to use the same bolt holes so it looks like a no.
Or does anyone make a sumpguard for a winch bumper?
Post #959830 28th Jul 2022 1:42pm
camelman
Depends which winch bumper you've got. a Lot of them only use the same 4 bolts as per the normal bumper so fit fine with a sump guard.
Post #959836 28th Jul 2022 2:21pm
Assuming you mean steering guard rather than sump guard (since the sump is protected by the front axle) then the answer is yes, usually they are compatible. As camelman notes there are however bound to be exceptions.
The photo below shows mine with a Mantec bumper and a Safari Equip steering guard with receiver hitch.
Post #959855 28th Jul 2022 4:20pm
Dean Watson
Hi
Thanks for the replies
Winch bumper has the standard 4 bolts for into end if chassis rail but also 2 legs going further diwn chassis, looks like these collide with brackets for steering guard
I think i have have solved it winch bumper compatible ones have very thin brackets that go inside the winch bumper mounts
I will try to post some photos
Post #959858 28th Jul 2022 4:48pm
I have a Husky bumper (with side angle iron brackets) and a Mantec steering guard (the flat Dural one as used on the camel trucks) and these fit together AOK.
Post #959964 29th Jul 2022 4:07pm
geobloke
Usually the steering guard brackets are designed to sit inside the bumper rear bolt mounts.
But as with all modifications... Some trimming may be required...
Post #959968 29th Jul 2022 4:44pm
rallysteve
Same here, First Four Husky winch bumper with Flatdog ali steering guard and both fit. Had to trim the steering guard brackets a little to clear the reinforcement on the underside of the bumper but think this is specific to this particular bumper design with the chunky lashing points underneath.
Post #959986 29th Jul 2022 7:31pm
