![]() | Home > Td5 > Trailer Light with Indicator |
Your best bet is to go around all the earth points, clean them up and you'll have another job ticked off.
The trailer light is supposed to flash once each time that you indicate without a trailer plugged in. If it's coming on on its own though, there's a problem somewhere. I'd start by checking the condition of the towing socket and the wiring to it, looking for corrosion that might be bridging to earth or damaged cables. Darren
Following on from LRA. If your Defender has had a replacement rear cross member it is possible the garage cut the loom and re-spliced it back together afterwards. This could be a problem area depending on how well the loom was repaired after the cross member welding.
Craig772 Member Since: 23 May 2022 Location: Cannock, Staffordshire Posts: 75 ![]() ![]() ![]() |
@Geobloke Brill, that's a v. useful diagram. I'll also follow the loom back and check for joins. Cheers.
@LandRoverAnorak That's a bit counter intuitive, you'd think it would be the other way around. Good to know. Yes, I am going to investigate the socket and clean it up if neccesary. It's 7 pin and I have 7 pin trailers and a 13 pin caravan so may look to install a double socket to avoid using the caravan adaptor. I haven't tested that yet but the 13 pin to 7 pin I used on my previous vehicle for the trailers worked OK so I am not sure it's worth the effort and I don't use anything besides the lights. @ |
barbel jim Member Since: 12 Dec 2012 Location: Northants Posts: 1451 ![]() ![]() ![]() |
You can check all the earth points, replace and add extras and still have the dam thing illuminate when it feels like it
Procta Member Since: 04 Dec 2016 Location: Sunderland Posts: 5337 ![]() ![]() |
I have had a problem with mine staying on, turned out to be the relay sticking on ![]() In the words of my Good Friend, Gary Forrest 1980 -2025 " we will work something out" |
