![]() | Home > Maintenance & Modifications > PAS to manual conversion? |
htb2 Member Since: 02 Nov 2018 Location: Carmarthenshire Posts: 548 ![]() ![]() |
Yes early manual 90/110 steering box will fit, with appropriate steering column shafts.
kenzle8a Member Since: 12 Feb 2020 Location: None Posts: 1074 ![]() ![]() |
Can you get hold of an electric pas pump from anything else locally? A lot of people use various items like the mercdes or mini ones
famousdefender Member Since: 20 Jul 2022 Location: hampshire Posts: 4 ![]() ![]() ![]() |
yeh for sure there's pumps out there, it was mainly to wanting simplification, no oils, sounds, less drain on battery and my current steering box leaks like a beast. so it's a combo of things!
Do you need to change the steering shaft (from steering wheel through bulkhead) or just the articulated shaft from steering box to bulkhead? |
