![]() | Home > Puma (Tdci) > BAS Intercooler |
Co1 Member Since: 19 Aug 2018 Location: North Yorkshire Posts: 3755 ![]() ![]() ![]() |
Have you got Air Con? I fitted a BAS intercooler this last weekend and you will need to move the condenser forward to accommodate. Other that that, it’s pretty straight forward. You might as well get hold of a silicon hose kit, if yours haven’t split yet it’s only a matter of time.
nick.bw Member Since: 26 Oct 2020 Location: Essex Posts: 77 ![]() ![]() ![]() |
Yep. Have AC
Did think about the silicon hose kit but just recently had a replacement hose so thought I would wait until it perishes a bit before going silicon |
silvermilnec Member Since: 23 Nov 2021 Location: West Yorkshire Posts: 27 ![]() ![]() |
I got the intercooler fitted last week, very pleased even without a map it pulls better and sounds better.
I did get my local garage to blank the egr and turn it off, we found a slit intercooler pipe so upgraded when fitting. Now tempted to get a map now black smoke has gone. These things can cost thousands ![]() |
Avelingporter Member Since: 25 Jan 2016 Location: Southampton Posts: 407 ![]() ![]() ![]() |
I think they are a great upgrade. I got mind from BAS at the Peterborough LR show. BAS fitted it for free while I had a look around. (I did book it in with them before the show). Definitely worth getting the hoses done at the same time IMHO.
I didn't even realise they are only 20 minutes from me so just turned up a few weeks ago and they had just got some ready for fitting.
JOW240725 Member Since: 04 May 2015 Location: Suffolk Posts: 7930 ![]() ![]() ![]() |
I'm afraid I can't help with tips, as I had my BAS170+intercooler+silicone hoses fitted by Pete Bell himself. It is certainly not easy but mostly access issues. It took Pete about 2 hours from memory (it was 7 years ago) and certainly a knack to doing it. Any issues Pete is very good over the phone.
I would suggest fitting silicone hoses as the orginals are well know for failing. Good luck!! The results are great!! ![]() MY2012 110 2.2TDCi XS SW Orkney Grey - http://www.defender2.net/forum/topic43410.html MY1990 110 200TDi SW beautifully faded Portofino Red - https://www.defender2.net/forum/post743641.html#743641 MY1984 90 V8 Slate Grey - https://www.defender2.net/forum/post744557.html#744557 Instagram @suffolk_rovers |
Ianh Member Since: 17 Sep 2018 Location: Essex Posts: 2474 ![]() ![]() |
I’ve done a BAS IC replacement on my 2.2 110 with aircon, inc hoses and main coolant radiator at the same time, so happy to provide any advice needed.
I would say 60 -90 mins max,inc a cup of tea if using existing hoses. Where in Essex are you ? Pm me if you don’t want to share publicly, I may be near by and possibly be able to help you do it ![]() |
