Home > Maintenance & Modifications > Help! Air con pipe in way of BAS intercooler install?
Co1
My intercooler failed this week so I’m replacing with a unit from BAS. All good, except I can’t see how it can fit with the AC pipe that runs along the back of the condenser. Any thoughts?
Post #958460 15th Jul 2022 7:26pm
Dinnu
I never knew that there was a pipe crossing behind the condenser, but I never looked for it either.
Unfortunately cannot check how mine is until tomorrow evening. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #958465 15th Jul 2022 8:16pm
Co1
Mine is not factory fit, it’s aftermarket, which is concerning!! Worse case I reckon I can re-route round the front and get it re gassed. Any thoughts on a safe way to release the gas?
Post #958468 15th Jul 2022 8:37pm
Dinnu
Need to be careful with aluminum pipes. Aluminum work hardens very fast and can crack without warning.
Usually AC service centers can recover your gas. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #958471 15th Jul 2022 8:44pm
Co1
Cheers Dinnu, but without the intercooler I can’t drive to the air con place so I think I need to discharge on the drive. Any advice, just crack a joint and let it out?
Post #958479 15th Jul 2022 10:11pm
Dinnu
I guess that is the easiest way. Doubt if the environment will thank you. Do not breath it. You might see some oil coming out. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #958487 15th Jul 2022 11:47pm
Co1
Thanks Dinnu. Yes I know, not great is it. Was looking at whether Halfords or similar do some sort of recovery kit. The car is in drivable at the moment so I’m not sure what other choice I have.
Post #958495 16th Jul 2022 7:35am
Ads90
United Kingdom 2007 Defender 90 Puma 2.4 CSW Keswick Green
There are mobile ac service companies, we had our ac topped up on the drive by a man with a van.
Post #958496 16th Jul 2022 8:12am
Co1
Cheers Ads. Contacted my nearest mobile guy who was repairing a combine just down the road!! Came and sorted it for me and is making up a pipe for me as the condenser is now too far forward for the old one to fit. Bit of a result!
Post #958520 16th Jul 2022 3:15pm
Co1
Just to close this off. I got myself a new pipe made. However, I also spoke to Cool Air Logan who make the aftermarket kit that I fitted and they are aware of the issue with the BAS intercooler (and probably others) and actually have a hose that you can buy that routes under the condenser, rather than round the back. Good to know. Their customer service is also incredible. Absolutely first rate.
Post #959305 23rd Jul 2022 6:54pm
