Home > Td5 > Making use of space under front seats… move ECU/battery?
phillips321
2005 Defender 110 2.5 TD DCPU Belize Green
So I’m tempted to fit a centre front seat which means I’ll loose my cubby box and all of the storage that it offers.
As such I find that there’s lots of wasted space under the drivers and passenger seats that I could use.
Has anyone come up with a clever way to make use of this space by accessing it from a flap in the front of the box behind the legs? And is there an easy way that the ECU can be moved to the battery box or vice Versa so that I have one large storage compartment?
Thanks in advance
Post #958197 13th Jul 2022 8:09pm
roel
Netherlands 2003 Defender 90 Td5 PU Caledonian Blue
I have a 90 and put my ECU against the bulkhead between the front seats. The wireloom ist just long enough, the only thing you have to extent is the hi / low transfer box sensor.
I am not sure if a flap to get to the box below the seat is practical.
I use the space for some basic spare parts, oils and a bottle jack. Roel
1984 90 2.5 na Diesel - RR V8 (1994-2001)
1997 Camel Trophy Discovery 300TDI (2001-2009)
2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts.
2003 90 Td5 (2009-now)
Post #958202 13th Jul 2022 8:52pm
SteveK
United Kingdom 2002 Defender 110 Td5 HT Rimini Red
It's up to you how you configure your vehicle, but personally (having had a 300 TDi with a centre seat and my current TD5 with a cubby box) I would never have a centre seat again!
The centre seat is small and not particularly comfortable and arms and legs tend to get in the way of the driver. I had fold out side seats fitted to the rear of the TD5, however you need to be aware of the regs regarding these!
Anyway the cubby box is useful place to store torches, first aid kit, replacement bulbs and the locking wheelnut key!
Post #958337 14th Jul 2022 7:02pm
Re: Making use of space under front seats… move ECU/batter
phillips321 wrote:
Has anyone come up with a clever way to make use of this space by accessing it from a flap in the front of the box behind the legs?...
I have seen someone with a Series vehicle who cut a hole in the side of the seat box facing the door to allow access to the storage within. They had fitted alternative seats which were not removable so couldn't access the lids in the usual way.
The openings were accessible easily with the doors open, but the limited clearance between the seatbox and the door when closed meant that stuff couldn't fall out when the doors were shut, and there is no need to try to cobble up any kind of flap.
I think that this is a more sensible approach than cutting a hole in the front of the seatbox since it doesn't increase the risk of all the junk flying out under heavy braking.
Post #958345 14th Jul 2022 7:51pm
phillips321
That’s a great idea to come in from the side!
Now I just need to figure out how to move the ECU so I can make use of the drivers side seat box for things like binos and gloves
Post #958362 14th Jul 2022 9:48pm
roel
http://www.defender2.net/forum/post482777.html
Here are some pics I posted here earlier how I did it with my 90. Roel
Post #958370 14th Jul 2022 10:38pm
lightning
The centre seat is great if you are driving, and fancy the person who is sat in it.
Post #958371 14th Jul 2022 10:38pm
roel
But he or she might refuse the next time or take you to court. Mr. Green Roel
Post #958375 14th Jul 2022 10:48pm
lightning
Yes you are right of course, we are not in the 1970's any more.
Post #958399 15th Jul 2022 8:37am
