Home > Td5 > 2003 TD5/90 Missing relay R211
TomS
United Kingdom 2003 Defender 90 2.5 TD HT Epsom Green
I've been trawling with the thread search for an hour, so apologies if this has already been covered, but here goes:
In the base of the under-seat fuse box there are a group (6, I think), of white connectors which plug into the base of the fuse box. The white connectors house female spade terminals which engage with male spades protruding from the underside of the box. Fusible link 3 from this fuse box should have a Brown/Red 4.0mm csa wire going to a relay 211. Only trouble is, there's no wire in the connector, so I can't find R211.
Why do I want this? I need to take a line from relay R211 and thence to fuses 33,34 and 35 in the passenger compartment fuse-box for heated seats and electric windows.
Can anyone tell me:
1. Where I can buy the female spade which goes into the white connector under fusible link 3
2. Where relay 211 is normally situated so that I can locate it or if necessary fit it
3. What type of relay is it so I can get one if I need to
4. Where the white/green wire that should be coming out of this relay goes to? (I think probably the oil pressure switch but I can't see where the 'right' place is to pick that up.
Thanks in advance,
Tom.
Post #958188 13th Jul 2022 7:39pm
andy2111
United Kingdom 2002 Defender 110 Td5 HT Bonatti Grey
Post #958189 13th Jul 2022 7:44pm
TomS
Thanks, Andy - it tells me what they do, but I'd like to know where R211 normally goes and whether I can get the terminal to plug it in under FL3. And where I connect to the oil pressure (?) switch.
Thanks,
Tom.
Post #958190 13th Jul 2022 7:53pm
andy2111
Not seen a relay described as R211... What does it control?
One more shot... Might help with oil pressure switch question
https://issuu.com/carakoom/docs/defender_my2002_wiring_diagram
Post #958200 13th Jul 2022 8:40pm
TomS
Hi, Andy,
Thanks for that. I do have a copy of this wiring diagram, but it doesn't tell me where R211 is (or where to put it if I have to add it), nor where Header 0285 is, which is where the engine running (oil pressure?) line should run to.
Relay 211 is the one referred to in the wiring diagram as Relay-ignition.
Thanks for your help - any additions gratefully received!
Tom.
Post #958268 14th Jul 2022 11:19am
rallysteve
The relay would have only been fitted on vehicles with E/W / Heated Seats from the factory. The white/green wire is a general ignition live signal.
If you can find a copy of the electrical library online it should show you header and relay locations.
Post #958276 14th Jul 2022 12:14pm
TomS
Thanks, Steve. That's helpful. Is the elecrical library different from the wiring diagram manual?
Tom.
Post #958281 14th Jul 2022 12:39pm
rallysteve
Yeah the electrical library includes photos and info for all of the connectors in the vehicle too (although there are quite a few errors in it!).
I have taken some photos of hopefully relevant/useful bits for you from my paper copy. You will see that R211 is fed from Header 0285 with the ignition signal but I cannot recall where the earthing is taken back to (says 0287 but that doesnt exist) so will be one of the others behind the center console.
Any more info let me know, have spent a lot of time studying and modifying 02> looms for two Defenders.
Cheers,
Steve
Post #958284 14th Jul 2022 1:28pm
TomS
Brilliant! That book is the missing link! I'll find one. Many thanks, Steve.
Tom.
Post #958307 14th Jul 2022 3:27pm
TomS
Hmmm. Seems the wiring diagram and the Electrical Library are at odds. The Library says that fusible link three feeds a connector called the Ignition relay C0218, whereas the Wiring Diagram (p28) shows that it feeds Relay-Ignition R211. But don't lets be picky and let's assume it's the same one. It at least gives a location on the RHS of the Transmission tunnel fuse box. The rest I can track down, thanks, Steve.
Any idea where I can get the connector that goes into the bottom of the under-seat fuse box?
Tom.
Post #958310 14th Jul 2022 4:05pm
rallysteve
No problems Thumbs Up
In theory both are right. C0218 is the socket for relay R211. If you look at the wiring diagram closely you will see that the four connections to R211 are actually C0218 (pins 85, 86, 87 & 85 as per normal automotive relays).
The connector which goes into the under seat fuse box (C0571) should already be there as position 3 of it is shown as populated for all models and position 2 on all TD5 engines. You should only need the crimp terminal for it to populate the third position. I will try and have a look at at a spare loom tomorrow as I might have some spare terminals.
Cheers,
Post #958313 14th Jul 2022 4:40pm
rallysteve
Dug through my spare sections of TD5 bulkhead loom and have found C0571 connectors, so you can see the teminal type:
Blade measures approx 7.8mm wide so i believe these are Sumitomo .305" blades. I think i have some new ones somewhere but alternatively I have dug this out if it helps you:
Correct terminal already installed and approx 2.7m of 3mm2 cable which oringally ran from C0571 right to the lighting stalk so should be long enough for you to terminate at the bulkhead fusebox.
Cheers Steve 02' 110 TD5 Double Cab Rebuild Thread
Post #958427 15th Jul 2022 2:46pm
Penfold_6290
United Kingdom 2002 Defender 110 Td5 CSW Epsom Green
Re: 2003 TD5/90 Missing relay R211
Tom.
Tom, if you Google "Land Rover Defender Td5 Electrical Library" you will find links to online PDF versions, same if you search for wiring diagram. The library shows all the connectors, their locations and how the connections are orientated. An absolute must for anyone who dabbles in the dark arts of Land Rover electrics
Post #958430 15th Jul 2022 3:24pm
TomS
Rallysteve: Thanks for the pix. Nearly sorted!
Penfold6290: Thanks for the hint. I've now got one downloaded. Great addition to the library.
I PM'd PaulMcC and it seems he has nearly all the bits I need.
Thanks for your help, guys.
Tom.
Post #958807 19th Jul 2022 9:44am
