Home > Puma (Tdci) > Assembling an in-car toolkit, advice welcome.
Page 2 of 4 <1234>
Gasket
Thanks for your replies everyone.
For completeness, I found a breakdown of the contents of the Land Rover kit mentioned above - quite a lot of things that are useless in a Puma, but I'll share it anyway:
3/8" square drive BiHex Sockets:
10mm Dog Guard mountings and thermostat housing.
11mm ?????????????
12mm Not found yet....
13mm Not found yet....
21mm Deepreach. Sparkplugs on V8 not 300TDi, bleed valves radiator and wheel nuts!
Spanners: 10, 11, 12 & 13. Combination BiHex ring and open jaw with 15 degree offset.
Plastic coated linesmans pliers sidecutting 6"
Plastic coated Plumbers monkey wrench 10"
Spark plug gapping tool.
Insulating tape 12mm roll of.
Screwdriver handle, black plastic.
Blade slotted and phillips 6".
Blade phillips, angled. (Carbs on V8 use only?)
3/8" Sliding T-bar 8"
3/8" Extension 6"
3/8" Extension 3"
Anyway. I'm getting closer on putting a kit together from my spares. The trick is paring it down to the essentials for a kit to live permanently in the car to support euro touring, this is the list I have so far:
1x 12oz engineers hammer
1x small chisel
1x 5mm head punch
1x medium sized adjustable spanner
1x pair waterpump pliers
1x pair linesman pliers
1 x pair medium-sized molegrips (flat or curved blades?)
1x pair crimping pliers/wire strippers and a few crimp connectors including a few heat shrink solder butt connectors (for real emergencies only - like for cutting out a bit of melted wire)
1x blowtorch type lighter (already have - works for the above and for BBQs)
1x 1/4" bit driver with quick chuck (the one I have is this https://www.tengtools.com/uk/products/bits...ver-183mm)
1x set of flat/ph and pz screwdriver bits inc. torx and allen bits
6 (or 7?)mm hose clip driver socket to fit the bit driver
1x set of combination spanners (open to size suggestions here, thinking 10, 13, 14, 16, 17, 19 plus 1x 9/16" for props)
1x 3/8" ratchet
1x 3/8"dr 3" long wobble extension
1x 3/8"dr 6" long wobble extension
1x set of 3/8" dr 6pt sockets (again, open to size suggestions, these would match the spanners - would need to include 9/16" for the props)
1x 13mm 12pt socket for calipers
Small selection of Torx bit sockets (these would be for sizes too big for the driver that need a ratchet, thinking gearbox drain plugs but am clueless when it comes to Torx sizes)
1x 52mm hub nut socket (driven by the extending 1/2"dr wheel brace I've just bought)
Folding Stanley knife
Roll of insulation tape
Mini-roll of duck tape
Roll of self amalgamating tape
1x LED torch
Post #958167 13th Jul 2022 4:38pm
Leamreject
Italy 2011 Defender 90 Puma 2.4 HT Fuji White
Shouldn’t it include “spare vehicle” Rolling with laughter Ride like you stole it!!
If I’m not on a bike it’s because only a 4x4 will do…
2011 2.4 Puma 90 HT
Post #958169 13th Jul 2022 4:41pm
Gasket
yup - touch wood its never let me down but am driving to the alps in January and the sensible bit of my brain is telling me to take the Mrs' Hyundai.
Just remembered I had a stack of Dewalt Toughsystem2 boxes sitting unused up at the unit, so that's the box for this lot sorted. ShadowFoam even sell inserts custom made for them - my god this is getting daft.
Post #958172 13th Jul 2022 5:02pm
macfrank
I use these most often Smile
Oh, and a nail-like tent peg to check swivel grease level Whistle
Post #958179 13th Jul 2022 5:40pm
Gasket
thats a really nice set, thanks for sharing.
Could I ask which sizes the 5 bits to the right are as it looks like you've selected the bits yourself rather than those that came with the standard Wera set: https://www.amazon.co.uk/10-pieceKraftform...&psc=1
Here's a bit of good fortune for people who appreciate such things: The original plan was to store the tool box and 1st aid/bulbs/spares/warning triangle, hi-vis etc under the seats and clipped to the sides of the cab... but in repurposing my existing spare tools for the project I've just dug out all of my afore mentioned DeWalt Tough boxes. I'm a massive fan of these - really well made, waterproof and with a vent. Anyway - I have two ToughSystem 1 cases and a load of Toughsystem 2 cases. The two older ones are technically compatible with the later ones, but never quite fit right - so I was going to get shot of them.
I'm also about to remove the rear seats.
Turns out a DeWalt (or Stanley equivalent) DS150 box fits absolutely perfectly into the recess left behind when the seats are removed. There are even two pre-existing trim holes in the side panel that can be used for a bungee and some rubber buffers. Can't quite show it with the seats still in the way, but you get the idea from the images: even the height is perfect - sits just below the window.
So I can use my set to have one box each side - one for recovery bits/1st aid/bulbs/warning triangle/etc and the other for tools. I'll obviously make a light canvas bag or something out of modus seat material to put each of them in first to keep them out of sight.
ends up being a bit like the L663 Side mounted boxes... only inside.
Post #958182 13th Jul 2022 6:24pm
macfrank
Smile Indeed. I'll check over the weekend. Turns out I don't have a written list of the tools I carry around - I will correct this negligence ASAP Laughing
Post #958194 13th Jul 2022 8:00pm
The Zee
United Kingdom 2014 Defender 110 Puma 2.2 USW Indus Silver
I'd add a good 27mm 1/2" Drive Impact socket to remove the wheel nuts, the one JLR supply is trash!
I have one of these : https://www.tengtools.com/uk/products/sock...etric-27mm
Which I wraped a piece of bicycle inner tube rubber over to prevent damage to the wheel.
A good socket that can't slip and is a precise fit on an extendable wheel brace is what is needed on a dark wet night with a puncture. Zaid-M
www.DefencePhotos.com
2014 Defender 110 Utility, 2.2 Puma, Indus Silver
Not just transport more like a religion
Post #958222 13th Jul 2022 10:28pm
spudfan
Ireland
27mm also does the Puma engine oil filter housing. 1982 88" 2.25 diesel
1992 110 200tdi csw -Zikali
2008 110 2.4 tdci csw-Zulu
2011 110 2.4 tdci csw-Masai
Post #958224 13th Jul 2022 10:46pm
The Zee
^ Thank you, never knew that Thumbs Up Zaid-M
Post #958226 13th Jul 2022 10:49pm
Gasket
I’ve actually just closed another thread where I was oooking for wheelbrace advice. Based on suggestions I got a Teng extending brace and a matching 27mm socket: just like yours except standard depth.
Post #958233 13th Jul 2022 11:51pm
nitram17
I never us an extension bar .With a 2 pound hammer ,a half inch sliding t bar and 27 mm socket i have not yet come across a wheelnut that wont come off in seconds.........(huge trucks excluded )
Post #958236 14th Jul 2022 2:49am
Merlin
I carry the Halfrauds kit and a few other things. Duck tape, air pump, WD 40 and cable ties are a must and most used. Wheel bearing kit, both sizes of UJs, fan belt and an alternator are carried for longer journeys.
Peter
Post #958286 14th Jul 2022 1:33pm
spudfan
Ireland
Tom Sheppard in his 90. Far enough he was overlanding!
Post #958308 14th Jul 2022 3:50pm
Gasket
wow - that looks ace. I can't quite make out all the text when zooming in tho, it gets a bit blurry. Just tried to find a copy of the book (tom sheppard vehicle dependent expedition guide) but its mega-bucks for a copy.
Post #958314 14th Jul 2022 4:57pm
spudfan
Ireland
Maybe it will be clearer in two parts. I bought the book in 2001.
Post #958323 14th Jul 2022 5:55pm
Page 2 of 4 <1234>
