Ignition switch?
Yesterday when I turned the key to the crank position the dash lights went off and nothing else, no click just a blank dash. Dash lights came back on when turning back the key from the crank position, repeated a couple of time and then it started.
Would the most likely culprit be the ignition switch on the end of the lock housing?
(1989 Ninety)
Thanks in advance.BORG - Bucks & Oxon 4x4 Response Group
11th Jul 2022 8:04pm
