![]() | Home > Maintenance & Modifications > Cruise control buttons and stalks |
Linds Hanson Member Since: 16 Jan 2021 Location: Cornwall Posts: 529 ![]() ![]() |
The cowling is cheap enough just buy a spare whilst they are still available make sure to get a late type as they are different on late cars
blackrock Member Since: 01 May 2022 Location: Hampshire Posts: 57 ![]() ![]() ![]() |
Yes, i wondered about that, good idea.
Andrew |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17911 ![]() ![]() ![]() |
I believe that the hole you describe is a left-over from the days of petrol engines and was for the choke control.
That makes a lot of sense.
Andrew |
It makes sense on planet Landrover, where evolution used to be measured in geological terms, but it is amusing to reflect that the last new Landrover design to have a choke control (as far as I am aware) the Stage One V8 manufacture of which stopped in 1985. So that hole is to accommodate a feature which hasn't existed for 37 years.
More likely the early petrol 110's as the column shroud is different from the Series III vehicles. Still a looong time though
![]() 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
Rosco Member Since: 03 Dec 2010 Location: Burntwood Posts: 1872 ![]() ![]() ![]() |
But oddly after 30+ years of fitting a bung to fill a reduntant hole they changed the moulding to remove it close to the end of production.
Its missing from my 2014 model 2007 - Stornoway Grey 90 XS SW - Gone 2002 - Black Discovery II - Gone 2014 - Montalcino Red 110 XS SW |
It changed when DSC had to be fitted because the steering angle transducer couldn't fit in the old shroud.
I'd actually forgotten that there was a carburetted petrol engine available in a coiler, so thanks for the memory jog. As you say, the shroud will date from that, not the leaf-spring era. I wonder which would have been the greater cost, modifying the injection-moulding tooling to delete the hole, or thirty years of buying and assembling rubber grommets. I have my suspicions! At least Bob-the-grommet-fitter kept his job for thirty years, as well as Steve-the-grommet-checker. |
Gasket Member Since: 30 May 2020 Location: Manchester Posts: 629 ![]() |
I have a similar approach with my 90 - I don't like to drill holes.
In this case, as mentioned above - just buy a take-off upper and lower cowl off ebay for a few quid and put either your original or the new one in the loft. Using the bung would leave the stalk at a weird angle. |
Yes, the hole on the right hand side didn't really work out and I ended up drilling a hole on the left hand side.
After a few hours of mainly trying to route cables I have finally managed to fit the kit and it all works. It seems like a nice kit, the cruise works well and all the cutouts on brake and clutch work. I haven't managed to get the two preset speeds to work yet, but that's probably operator error. One nice thing this kit has (CANM8 kit) is a diagnostic mode that lets you check your wiring without having to drive around checking the cruise function. All done using a multi colour LED. The left hand stalk is usable, it looks OK, but it is a bit crowded now on that side. I tried indicating with the cruise stalk a couple of times, but I'll get used to it. I may have a look at building a small panel with the switches on it instead sometime as I think that might be a better way to control the unit. the wire on the kit was a bit short for the clutch switch signal, but just about reached. Andrew |
