![]() | Home > Puma (Tdci) > Door locking issue |
| markb110 Member Since: 22 May 2010 Location: Guildford Posts: 2708
Is the yellow wire damage within the rubber conduit between the bulkhead and door.
It happened to me, you can either get a complete loom or pull out the wire either side of the conduit then add a repair piece then pull the bulkhead side back into the rubber housing. I went for the repair as i am a cheapskate.... |
| Craig-C Member Since: 25 Aug 2017 Location: Staffs Posts: 40
Yes, I had the same. Turned out to be a linkage in the door was partially seized up. The plastic rod going to it was flexing enough to unlock but would then re-lock its self. Check if the plunger is only coming part way up. Mine was.
Good luck. FFRR TDV8 sold PUMA 90 :0[==]0: 90 TD5 CSW XS MX5 (NC) BMW 320 BMW 1200 GS Adventure SUZUKI HAYABUSA |
| All times are GMT |
