Home > Technical > Access to Throttle pedal nuts
beardiedog
England 2003 Defender 110 Td5 G4 Challenge Tangiers Orange
I am getting water entering the cab via the throttle pedal from the inside when it rains it also looks like there is a bit of corrosion around the pedal so I thought I'd remove it and have a look but really struggling to get to the 2 nuts that are in the engine bay. I have ABS and which takes up a bit of room but it's the air pipe going to the snorkel which I assume is standard any advice I cannot event see the 2 nuts. RHD 2002 TD5
Post #953968 29th May 2022 1:55pm
Have a look from underneath, between the bulkhead and the inner arch.. or stand on a tall step. They are easier to get to that way, but it’s best with another person, one in, one out.
Post #953970 29th May 2022 1:59pm
beardiedog
Ah ok thanks, will try underneath when I have a helper
Post #953977 29th May 2022 3:06pm
