Home > Maintenance & Modifications > Snap-On Impact Driver PIT120 Operation??
Cubflyer
United Kingdom 1994 Defender 90 300 Tdi SW Arles Blue
Evening all
I've got a few seized screws and bolts around my Defender 90. Several folk have commented about using an impact driver so when one came my way in the week I got it. Sadly it has no instructions and I can't find any.
On the body it has a left and right arrow with matching On and OFF. So you can rotate the 3/8" stub left and right which I presume is On and Off ... BUT, I was expecting some sort of Clockwise or Anti-clockwise setting to extract or tighten a screw or bolt.
Can ANYONE clear up this tool's operation please ..
Many thanks
John
PS: Viewed several Youtube channels and still not clear 2010 Defender 90 300Tdi CW (White/1994)
2021 Defender 90 300Tdi SW (Blue/1994)
Post #953754 26th May 2022 11:07pm
landy andy
You turn the 3/8 stub to the way you wish it to operate. I think the on / off is “nut on, or nut off” which I prefer as tighten/loosen, but obviously this is only for standard threads, not reverse thread.
The above is bases on a standard impact driver, no a Snap-on one, but can’t see it being any different.
Post #953760 27th May 2022 4:34am
Co1
Could you not just practice on a nut and bolt in a vice and find out? I’m pretty sure it’s “normal” as I’m off is to remove the nut/bolt. Just put it on, take up any slack and hit it with the mallet.
Post #953763 27th May 2022 6:01am
Cubflyer
Should have mentioned that I'd tried that with no obvious effect ... what I think "Should be" straight forward is not. 2010 Defender 90 300Tdi CW (White/1994)
Post #953777 27th May 2022 7:54am
landy andy
Post #953778 27th May 2022 8:01am
Cubflyer
Thanks Andy ... appreciate your time to find this article, the part I guess I was missing was to "Turn it in the direct you require" Thumbs Up
... and on a lighter note, love the "Step 5" ... NO GLOVES in sight Exclamation Laughing
Have a good weekend
John 2010 Defender 90 300Tdi CW (White/1994)
Post #953779 27th May 2022 8:11am
Dinnu
Are you going to use this impact driver on body fasteners?
Generally M6 body fasteners are very easy to shear off if nut is seized solid.
M8 are a bit harder, but still can shear off. So no hammering on body.
Of course as long as the bolt head or nut are not rounded.
Larger bolts used for suspension components.. I guess 3/8" drive is a bit too small? 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #953783 27th May 2022 8:31am
rallysteve
The on/off thing seems to be a stupid Snap On thing. It is the same on a couple of my Snap On ratchet handles.
Post #953813 27th May 2022 2:22pm
Cubflyer
Hi Steve, maybe me but still not totally clear. I'm working on Off = Anti-clockwise (Undo) and On = Clockwise (Tighten).
But really not clear, I have a Norbar 1/2" and that's crystal clear.
Post #953816 27th May 2022 2:34pm
