Home > Puma (Tdci) > What are these wires under the carpet? |
UtilityTruck Member Since: 09 Jan 2014 Location: Oxford Posts: 463 |
Is the first wire for the handbrake switch perhaps?
Second wire looks aftermarket? Due to the way it’s taped to the seat box..? 2014 Keswick Utility 2.2 |
19th May 2022 5:10pm |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 16809 |
I would (almost) put money on neither of those being there when the vehicle left the factory - not even Landrover would do something that shoddy! It is, I suspect, evidence of an inept previous owner.
The only sure way to find out what they are is to find the ends. Once you do this, all will become clear. Either that or cut them and see what no longer works. |
19th May 2022 5:40pm |
AKA the ‘high risk strategy’ 2014 Keswick Utility 2.2 |
19th May 2022 6:14pm |
Gasket Member Since: 30 May 2020 Location: Manchester Posts: 629 |
I’ll have a good look once I’ve taken out the mats. The weird thing is that the one taped to the front of the seat box is buried under a load of factory foam - it doesn’t look right, but I can’t think why a PO would have removed the seat box rubber covering - that’s the only way they would have had access to tape it.
Edit: the start and end points of these wires look about right: https://www.lrworkshop.com/connectors/defender-2007/C0091 Just need to work out where the routing should have been. Working theory is that when the body was off while I was having the chassis galvanised that they’ve ran the wires through the can instead of under it. |
19th May 2022 10:13pm |
All I can say is that on my 2007 Puma there are no factory wires between the carpet and the floor.
20th May 2022 7:31am |
hank Member Since: 12 Sep 2016 Location: South Wales Posts: 2218 |
People extend the orange central locking/alarm antenna wire to extend the range of the keyfob... Could be something to look for > 110 XS Double Cab
> Instagram @simonlanemind |
20th May 2022 8:21am |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6460 |
Have you got 13 pin or the 12S (aux - white/grey cap) tow electrics? 1988 90 Td5 NAS soft top
2015 D90 XS SW |
20th May 2022 9:07am |
Co1 Member Since: 19 Aug 2018 Location: North Yorkshire Posts: 3605 |
Tell me more Hank! My Key fobs has only ever worked when standing right next to the vehicle! Would love to get a bit more range! |
20th May 2022 1:23pm |
Just basic towing electrics Martin - a single 7-pin black (genuine LR) socket |
21st May 2022 12:39am |
Cragster69 Member Since: 15 Jun 2021 Location: Scotland Posts: 164 |
Details in this link https://defender90xs.blogspot.com/2014/11/...nsion.html It's on my to do list. Craig. “Don't believe everything you read on the internet.” ― Abraham Lincoln www.scotgrc.co.uk |
16th Jun 2022 9:09am |
There are many threads on it - this one has all the info you need https://www.defender2.net/forum/topic3107.html > 110 XS Double Cab > Instagram @simonlanemind |
16th Jun 2022 9:35am |
