![]() | Home > Td5 > Alpine Window Glass Thickness |
gilarion Member Since: 05 Dec 2013 Location: Wales Posts: 5135 ![]() ![]() ![]() |
Make sure you have a a seal filler strip tool as without one inserting the filler strip is almost impossible. And use lots of fairy liguid or silmilar as a lubricant.
Filler strip tool https://www.ebay.co.uk/itm/195004671115?ha...XQMXRQ8A6N For those who like Welsh Mountains and narrow boats have a look at my videos and photos at.. http://www.youtube.com/user/conwy1 |
4RF RDS Member Since: 19 Jul 2015 Location: Ottawa Posts: 987 ![]() ![]() ![]() |
If you are getting new seals and glass, I would say get the 5mm. It quieter
![]() ![]() ![]() 2003 Range Rover Mk III (Desmond FitzWilliam) 2000 Defender 110 CSW TD5 (CTX) 1992 Range Rover Classic (Lizzy) 1972 Series III 300 Tdi (Stanwood) 1967 MGB GT Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats. H. L. Mencken (1880 - 1956) |
Paddington Member Since: 15 May 2020 Location: Oxford Posts: 43 ![]() ![]() |
Thanks for the tips. i'm having the windows tinted and the glazier is going to replace all the seals at the same time - so i'm not doing it and he's got quite a portfolio of defenders he's worked on. There are certain things i'm happy to try but anything with windows i'm happy to pay.
lightning Member Since: 23 Apr 2009 Location: High Peak, Derbyshire Posts: 3337 ![]() ![]() |
Make sure the join in the seal is along the top edge and not the bottom, and make sure they use genuine LR seals.
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6698 ![]() ![]() ![]() |
5mm glass was fitted upto and including VIN numbers ending with EA344187
4mm glass was fitted from EA344188 The "E" is the model year. Slightly confusingly with 90/110/Defenders, the model year letters "A" to "G" were used twice, for 1984 through to 1990 (roughly corresponding to UK registration prefix letters) and again for 2010-2016 model years. Anyway, in this case, the change point is in the 1980s range not 2010s range [as it's given in the pre-Puma parts catalogue]. So a 2003 Defender sits after EA344188 and was factory fitted with 4mm glass. ![]() ![]() Last edited by Martin on 16th May 2022 1:13pm. Edited 1 time in total |
thank you for the enlightenment Martin.
Very much appreciated - and notes taken to avoid repeating the question. Kind Regards Neil |
