![]() | Home > Puma (Tdci) > Cutting Out |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5991 ![]() ![]() |
Check battery terminals and the terminals on the new cutoff switch. I’d also be concerned that there are cheap versions of cutoff switches, which I’ve had problems with in the past when used for high current such as winches, and jump starters. If it is a regular issue a temporary bypass is simple test.
BaronDefenders Member Since: 28 Jun 2019 Location: London/Cotswolds Posts: 924 ![]() ![]() ![]() |
Shall start with that.
It’s not a new cut-off, it’s been on the vehicle for years. However, it’s pretty much never used as it’s a faff to remove the key without the BBUS going off. So I’m wondering if it has started to corrode internally or melt. Charlie 1949 Series 1 80 (SOLD) 2002 Td5 90 (SOLD) 2008 Freelander 2 (SOLD) 1958 Series 2 88 Pastel Green (2019 LR Legends Best Restored) 1983 V8 110 Limestone (Previously owned by Tom Sheppard MBE) 2004 Td5 90 Santorini Black (Td5INSIDE Powered & Rebuilt by CSK) 2012 Puma 110 Zermatt Silver (Overlanding Build) Instagram: @BaronDefenders |
