Home > Maintenance & Modifications > Ignition barrel maintenance?
jfh
South Africa 2007 Defender 110 300 Tdi SW Chawton White
My Landy's ignition barrel has been sticky a few times.
It'll take a second longer to return after starting the Landy. First startup only and not every day, maybe once a week.
This usually happens when it gets colder here.
Is there a way to give it some maintenance?
I know that lubricant isn't supposed to be used on locks. Maybe contact cleaner?
Post #950803 28th Apr 2022 5:55am
Co1
Abus do a specific lubricant for locks, I use it on my external barrels and fuel cap after that started sticking. I imagine it would be suitable for this as well.
Post #950804 28th Apr 2022 6:09am
jfh
Will try and see if it's available here, but I doubt it. Lubrication of locks isn't a big thing in Africa Mr. Green
Post #950806 28th Apr 2022 7:12am
Dinnu
The reason why lubrication of locks is not recommended the lube will attract dirt, and dirt will make it worse. Possibly this also applies for the ignition barrel, especially if you keep the vents under the windscreen open.
Best lube for locks is actually graphite powder, as is a dry lubricant.
If you cannot get hold of graphite powder, just run a pencil (without the wooden part) on sand paper, and voila instant powder Laughing
Just bear in mind that the ignition is made of 2 main components- the lock itself and the switch behind it. It could be a switch problem not a lock problem. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #950809 28th Apr 2022 7:33am
Another vote for graphite powder - it's like magic. Darren
Post #950813 28th Apr 2022 8:39am
jfh
I know about graphite but how do you get the powder in when the lock is mounted?
Post #950817 28th Apr 2022 9:14am
Dinnu
Generally comes in a small bottle with a nozzle (applicator) and you can ‘puff it’ in. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #950820 28th Apr 2022 9:32am
Bluest
I used to have a can of dry graphite lube in like a solvent suspension. You squirted it in with an aerosol, the solvent flashed off leaving the graphite behind. Something like this: https://www.silmid.com/lubricants/graphite...l-Aerosol/ 2007 110 TDCi Station Wagon XS
Post #950831 28th Apr 2022 12:10pm
Balvaig
Scotland 2016 Defender 90 Puma 2.2 Landmark LE Corris Grey
Or rub the graphite on your key and insert a few times
Post #950832 28th Apr 2022 12:12pm
jfh
I might have some Spanjaard Air Dry Film.
Post #950834 28th Apr 2022 12:59pm
