Home > Maintenance & Modifications > Tip - Greasing the prop shafts
steveww
United Kingdom 2015 Defender 110 Puma 2.2 XS CSW Bronze Green
I have an air powered grease gun which helps. No flexible pipe required.
Put the transfer box in neutral
Jack up one wheel on the rear axel, leave the wheel on.
Wriggle under the Defender.
You can turn the prop shaft to expose the grease nipple.
Pump in some grease until the old dirty stuff is pushed out and clean grease comes through.
Wipe up as much of the old grease as you can.
Lower the rear axel
Jack up one wheel on the front axel.
Same as for the rear prop shaft...
Don't forget to put the transfer box into gear or you'll be rather confused when you try to drive later.
Post #950773 27th Apr 2022 7:55pm
DSC-off
Don't forget to chock the wheels either when jacking it up with the transfer box in neutral.
The handbrake will not be operational, nothing to stop it moving or running away. Shocked
Post #950776 27th Apr 2022 8:07pm
If you want to do a more thorough job, unbolt the flange at one end (at least, both ends is better) of the propshaft so that you can articulate the joint fully while greasing. It only takes a few minutes and significantly improves grease migration through the joint as well as allowing you to assess the condition of the needle-rollers. It also avoids any problems getting the connector onto the nipple between the yokes if you are using the original-style propshafts.
Post #950781 27th Apr 2022 8:25pm
steveww
Good point, well made. Fortunately my workshop floor is dead flat.
Post #950797 27th Apr 2022 10:08pm
