Home > Td5 > Brake disc wear/thickness
excossack
Just checking the specs of the front discs on the 110 in the Haynes manual
Vented disc 24mm thick (as new)
Max wear 1mm per side.
So that gives a minimum thickness of 22mm for a vented disc before it needs replacing ? 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #950753 27th Apr 2022 4:03pm
rallysteve
That is the same number i have heard before for the min thickness.
Think it is 12mm for solid discs. 02' 110 TD5 Double Cab Rebuild Thread
Post #950755 27th Apr 2022 4:35pm
excossack
2mm wear doesnt seem a lot. 1999 Defender TD5 110
Regards
John M0VAZ
Post #950778 27th Apr 2022 8:09pm
