![]() | Home > Puma (Tdci) > Rear crossmember crush tubes, missing? |
Gasket Member Since: 30 May 2020 Location: Manchester Posts: 629 ![]() |
EDIT: sod's law. As soon as I posted the query above, it dawned on me to look for a set of fitting instructions for a NAS rear step and, sure enough the crush tubes are there and it shows the orientation:
![]() Click image to enlarge Unless anyone pipes in to say its the wrong part to try and fit to my vehicle, I'll go and order a pair of them. EDIT #2: I've found the current part number for the brackets: KVX000020. So I can find it on LRWorkshop now and it definitely should have been there from the factory on my CSW, so has been lost when galvanising. Really good spot by the inspecting mechanic. Damn - now there's three different part numbers in play: alr3226 which was superseded by KVX000020 and anr3821. |
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3591 ![]() ![]() ![]() |
I have replaced those on a Td5 (just fabricated new stainless ones) and took the ones off my Puma for hot dip galvanizing. They looked identical between Td5 and Puma.
They go in through the ends of the crossmember, kind of a rotation motion. And yes, the tab to hold it from then will be towards the top of the crossmember. Very clever mud trap design ![]() 2012 90 CSW, 2.2TDCI, Santorini Black |
macfrank Member Since: 05 Nov 2015 Location: somewhere in the north Posts: 1124 ![]() ![]() ![]() |
This is how I got it out/in. Rotate it 180° once inside the crossmember.
![]() Click image to enlarge ![]() Click image to enlarge Also take care not to overtighten the bolts ![]() ![]() Click image to enlarge |
Dinnu /Macfrank.
That is really helpful, thank you both for your help - I’ll go and order the parts. |
If you get genuine ones, give them scuff them and give them some good paint.. they ruuuusssstttttt. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
nitram17 Member Since: 09 Jun 2014 Location: newcastle Posts: 2261 ![]() |
yrm do a bespoke ss version
https://yrmit.co.uk/product/316-s-s-seat-b...-defender/ |
BrickBox Member Since: 05 Oct 2021 Location: Wales Posts: 1014 ![]() ![]() ![]() |
What Is the purpose of these crush tubes? 2008 2.4 110 Utility Station Wagon XS.
Prevents crushing the chassis/outrigger when the bolts are nipped up. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
